1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
6.0 problems
Old 12-28-2016, 01:30 PM
mikeycars's Avatar
mikeycars
mikeycars is offline
6.0 problems
2003 6.0 is acting crazy again. Has new ICP, IPR, oil discharge tube, and hpop. It cranks right up but one time you crank it and all the gauges work correctly, especially the fuel gauge. The engine will idle perfect but when you accelerate it has a dead miss. May crank like that 2 to 4 times. Then you crank it and it runs like crap, and the gauges won't work, the fuel gauge goes past E and the light comes on. As long as that happens it runs terrible, but when the gauges are working it idles great but has a miss under acceleration! It was running fine, then just went nuts! Any ideas would be greatly appreciated!
Old 12-28-2016, 08:13 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Wiring harness chafing....Look it up on google...I seem to remember something... The early 6.0l wiring was messed up in spots.
Old 12-28-2016, 10:48 PM
mikeycars's Avatar
mikeycars
Thanks man, I'll look it up asap.
Old 12-29-2016, 08:00 AM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
Harness chaffing is part 1. Once that's addressed there might be an injector or two that are not working.
Old 01-01-2017, 09:51 PM
mikeycars's Avatar
mikeycars
With the holidays and the nasty weather, I haven't been able to check it yet but I have a guy that's supposed have a tool to check the injectors with. Thanks again guys, and Happy New Year to y'all!
bstarz40
12-14-2016 05:30 PM
newbie2006
03-30-2014 11:15 AM
Huntsman
40
03-14-2012 09:45 AM
Quick Reply: 6.0 problems
