Info needed
Old Dec 28, 2016 | 12:55 PM
1racer54's Avatar
1racer54
Post Info needed
Need a replacement chassis for a 1966 f100 2wd short bed in Charlotte NC area. Thankful for any info as to what will interchange. Ben told that the 67-72 should work but do not know for sure. Thanks for any info, Gary
Old Dec 31, 2016 | 06:47 PM
kdmercer311's Avatar
kdmercer311
I'm no expert, but if you're going to swap it all over, I'd find a modern Crown Vic frame and bolt your body to it. I have heard that the bolt holes line up. Don't hold me to it my twin I-Beam frame is still in good shape, but I'd like to do a Dent front end swap for the disc brakes and power steering.
Maybe a senior member will chime in and correct me if I'm wrong on the Crown Vic swap...
Also, any tips on the dent swap for me would be appreciated.
Old Jan 2, 2017 | 01:40 PM
RangerMercMan's Avatar
RangerMercMan
The crown vic swap has many a write up with video on the internet and appears to be straight forward. Keep in mind that if you are needing a "new" frame to work from that the V.I.N. is on the frame not the warranty plate so keep your old frame numbers.
Old Jan 3, 2017 | 04:40 AM
User 71024's Avatar
User 71024
the twin I-beam started in 65 and was pretty much identical until at least 79. There are slight changes to the rear of the frame, but easily modified.
and personally I have no idea why anyone would want to swap a car chassis under a half ton pickup. Twin I-beam is a nice riding truck. When I need a soft ride, I put a couple of thousand pounds in the back
Old Jan 3, 2017 | 05:38 PM
jowilker's Avatar
jowilker
1racer54 Welcome to and the Slicks Forum.
1965-72 should be bolt hole exchange. Please note the the go to vin is stamped on the chassis and should be noted with NC DMV when swapped for legal.
John
Old Jan 7, 2017 | 07:24 PM
Bostonbob's Avatar
Bostonbob
frame
I have a good 65 short bed frame
jkalin99
Jul 24, 2017 08:45 AM
fatboy1026
Nov 28, 2010 10:03 AM
Mcarver
Jul 3, 2010 02:04 PM
slavik
Dec 30, 2006 11:54 AM
wiley0ne
May 26, 2004 09:37 PM
