After long research i have located the Ford Part Numbers i need they for the factory installed A/C, They are
C8TZ-18472A and C8TZ-18472B , Are these available anywhere or is there a cross reference number for them? Or are there photos? and dimentions? Thanks
I'll bet long research. Those number aren't listed in my January of 1975 Ford microfische slide. But they do show up as being discontinued in my Obsolete slide dated January of 1977. So they were discontinued before this.
Sorry, but none show up at any Dealers, N.O.S. companies, Ebay, or Amazon on any of my locators. Your best bet would be to go to your local Ford dealer and have them try to match something up that you can at least splice in. All vehicle's 18472s are stocked together.
Thanks for looking for me, looks like we will be splicing heater hoses together to make up what we need, again thanks a bunch and Happy holidays!
You're welcome. I have seen some question mark shaped hoses before back on the 18472 shelves. It may end up being a few splices but what the heck. They will be hidden behind the unit.
Also, Ford had a hose bender part number D1AZ18573A (replaced C9AZ18573A) that clamped around a straight 5/8" hose to create about a 90* bend without crimping the hose. Like the one below I looked on evilbay to get a pic. They were a real beotch to snap shut over the hose.
xGreen Sales has both part numbers.
(800) 543-4959
xDennis Carpenter Ford has both part numbers.
800-476-9653
xRPN Parts has the D1AZ18573A.
888-864-9305
The following places also have the D1AZ18573A:
Green Sales Company
NOS Parts Ltd.
Recently UpdatedPart Number D1AZ18573A
Seller:NOS Parts Ltd.
Description:BENDER-HEATER HOSE
Phone (972) 937-2201
Price:Request PricingEmail:Send Seller Email Inquiry
Quantity:16
McDonald Obsolete Parts
Part Number D1AZ-18573-A
Seller:McDonald Obsolete Parts
Description:SUPPORT
Phone (812) 359-4965
Quantity:1Location:rockport, Indiana
Miller Obsolete Parts
Seller:Miller Obsolete Parts
Description:SUPPORT WRAPAROUND ELBOW (1P2)
Phone (607) 722-5371
Quantity:2
1957/67 & 1968 (thru 1/1968) bound paper Truck Parts Catalog sez for 1968:
C8TZ-18472-A .. Hose-Hot Water Heater w/integral A/C / preformed - 5/8" I.D. x 46" long.
C8TZ-18472-B .. Hose-Hot Water Heater w/integral A/C / preformed - 5/8" I.D. x 25.50" long.
Neither of these part numbers are listed in the May 1975 final edition of the 1964/72 truck catalog.
I always got a kick of the picture of that plastic hose bender in parts catalogs, as it was 'very suggestive.'
El Jeffe: Do you recall how long C8OZ-18472-B was? I think it was around 5 ft. This was a preformed (on one end) 5/8" I.D. hose, there are 4 available NOS
Think piecing hose together will be a better bet, rather than that hose bender, Thanks again for the legwork, And to your point it will be behind the box tucked away!
It seems like years ago NAPA had heater hoses with a metal strut in them that allowed the hose to bend sharply while the metal "backbone" kept it from kinking.
I think the C8OZ18472B was around 4 foot Bill. You know how our Parts Bins are 3 feet wide? I remember those C8OZ18472B being wider than the shelf but still fitting, for the most part, on them curved. And not much sticking out.
Hey Texas, the reason Bill keeps bringing this part number up is he does have a good point. If your local dealer doesn't have the pieces to splice together, you might consider the C8OZ18472B. It was around 4 feet long and has a pre-formed 90* on one end. This would give you the 90* at the heater core. You'd just have to splice in the elbow to send the hose through the firewall correctly.
My x-father in law has the dealer AC in his 70 c/s ranger an we used a gray barbed 5/8" 90* PVC from a loco plumping store like home depot that we spliced into that funky heater hose design as the loco ford dealer had any about 20 yrs ago and still holding up. Or leaks the can be seen. What a pain dropping the AC unit out enough to get to the hoses.
Orich
Orich
1968/72 F100/350:
Factory installed integral A/C is combined with the heater. The A/C controls are in the same panel as the heater controls.
The two types of dealer installed A/C are not combined with the heater. The two A/C switches are mounted on the bezel.
The deluxe dealer A/C bezel bolts to the entire underside of the dash. Economy A/C bezel bolts to the underside of the dash at the center.
Okay then it's factory AC that was in it. I can't remember which was dealer & Factory Air only seen one dealer air then all the other's I come across were Factory AC.
Hated those little pint size glove boxes they have Factory AC's.
Thank Bill, I'll try to remember which is which from now on.
Orich
Went to napa today and picked up 200.00 worth of heater hoses from all different years and bends, Once i find the right combo will post pics of how we did it and what hoses we used to make the bends
