Let's talk fuel tanks.......
Old Dec 26, 2016 | 10:58 AM
78 PEB's Avatar
78 PEB
Ok, I'm sure this has all been discussed before, but, I've had no luck with the search......I've got a '78 F150 4x4. It has the single rear mounted tank. I replaced the original 19 gallon with a 38 gallon a few years back and like the extra capacity. The problem I have is I am doing a 4BT swap and have read negative things about using a galvanized tank with diesel fuel. In fact Detroit Diesel and Caterpillar say it's a definite no-no. Apparently the sulpher in the diesel fuel will leach the zinc out of the galvanized coating and screw up an injector pump.......Don't know if it applies to Cummins or not........I have been thinking about using one of the higher end epoxy tank coatings but after researching those.....I think I can buy another tank for about the same price.......MY question is.......Where can I get a oversized (doesn't need to be 38 gallons but would be nice!) poly tank???? I've Googled and searched but not having any luck. Will the Bronco tanks fit a F150? Anyone know an answer???? TIA
Old Dec 26, 2016 | 12:04 PM
COFLHTK's Avatar
COFLHTK
They arent cheap, but aero tanks makes tanks that can use gas or diesel.
Ford Fuel Tanks - AeroTanks
Old Dec 26, 2016 | 12:44 PM
tabascom16's Avatar
tabascom16
I ruined 3 injection pumps on my IDI rather quickly. Switched to a plastic tank and went to a Cummins swap and never had a problem since.
I have not seen bigger plastic tanks. With the 4BT you will probably be getting almost double the mileage as your old gasser so a 19 gal tank won't be so bad.
Old Dec 26, 2016 | 01:46 PM
78 PEB's Avatar
78 PEB
I agree on hopefully double the mileage but 20 MPG @ 38 gal.......would give me 760 mile range.........Kinda digging that idea LOL
Old Dec 27, 2016 | 10:42 AM
Derfus's Avatar
Derfus
JBG offered bronco tanks and truck tanks in plastic in their catalog on my desk. A truck tank is 19 gallon only in plastic. The bronco tank is 25.5 gallon and 33 gallon. Maybe one of the Bronco tanks would work?
Old Dec 27, 2016 | 10:47 AM
78 PEB's Avatar
78 PEB
Yeah.....I have found the Bronco tanks on JBG......just wondering if anyone has used one before I pay the shipping to find out if it will work.........and yes......25.5 or 33 gallon would be better than the stock 19
Old Dec 27, 2016 | 11:37 AM
gittinwidit's Avatar
gittinwidit
The 78-79 full sized bronco 33 gal. tanks fit but you have to use the bronco bottom straps (or fab extended straps). Keep in mind it hangs down another 3-4 inches. There's a bolt-on hitch for the bronco that accommodates the 33 gal tank that provides protection. But you really need quite a bit of lift (tires / body / suspension / combo) especially on a long bed to be able to run the 33 gal tank without scraping it on asphalt on sharp inclines. And plastic doesn't play near as nice as metal does with asphalt.
Old Dec 27, 2016 | 07:37 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Dec 28, 2016 | 01:23 PM
redmt79's Avatar
redmt79
The Bronco 33-gallon tank does not use bottom straps, it uses a skid plate for support. Top straps sandwich it to the skid plate.
After reading this post I went and measured my 33-gallon tank clearance versus the spare tire carrier hanging under the rear tank of my F-150 4x4. The spare tire has all of 1/2" more clearance. So provided that a spare will not be mounted below the 33-gallon tank, I don't see there being any additional clearance issues.
Old Dec 29, 2016 | 07:43 AM
gittinwidit
Mine has these straps underneath and not a skid plate.
1978-1979 Ford Bronco 33 Gallon Lower Gas Tank Straps Pair-Broncograveyard.com
Old Dec 29, 2016 | 11:46 AM
redmt79's Avatar
redmt79
Yes, those are intended to replace the factory skid plate and may even make them work on a pickup when installing a 33 gallon tank. The OE skid plates can be tough to find as many rusted out over the years.
Old Dec 29, 2016 | 11:48 AM
gittinwidit
As for bottom straps to place a 33 gal, I've seen various tricks / fabrications to make it happen.
Old Dec 29, 2016 | 12:48 PM
77&79F250's Avatar
77&79F250
Ck out a 90-96 Bronco fuel tank skid plate?
Old Dec 30, 2016 | 11:15 AM
redmt79's Avatar
redmt79
Good idea...for that matter a person could probably use the tank too.
Old Dec 30, 2016 | 11:24 AM
gittinwidit
The diameter of the hoses changed and the pickup is totally different. Wiring is different as well. 90-96 had an internal pump that pumps more than a carb can handle. So a regulator would also be needed. Although the same size, it would only work if you swapped everything including wiring and added fuel injection. And you would have to fab up the nozzle that attaches to the bed as well. Or a combo of some sorts there of? Pretty sure there's other differences as well?
