Sponsored by: Real Truck
2011 f250 electrical problem
Old Dec 23, 2016 | 11:43 AM
Masterofyard's Avatar
Masterofyard
I went to replace a headlight bulb and now I lost electric in the cab. I have no interior lights, no power window or door locks, turn the key on, no crank, no cluster, no radio, no chimes, the upfitter switches work, the mirrors power fold and telescope. Have power to both fuse boxes and battery is fully charged. Any ideas??
Old Dec 23, 2016 | 02:46 PM
seville009's Avatar
seville009
Check the actual fuses?
was it the driver's side headlight that you have to pull the grill and everything off for? If so, take it all apart again to see if you accidentally pulled a wire off.
Old Dec 23, 2016 | 03:40 PM
Masterofyard
I did, turned out to be the accessory delay relay
Old Dec 24, 2016 | 05:34 AM
seville009's Avatar
seville009
Glad you found the cause. Just curious though in case it ever happens to me (2011 F350) - did you somehow accidentally diconnect it?
Old Dec 24, 2016 | 07:29 AM
Masterofyard
Accidentally disconnect what?
Old Dec 24, 2016 | 09:05 AM
seville009's Avatar
seville009
Sounded like the relay was somehow disconnected. Was it just bad?
Old Dec 24, 2016 | 09:14 AM
Masterofyard
It wasn't disconnected, we was bad. For some reason the tues didn't blow...it's #18 on the fuse box on the rt side locker panel fuse box...which is where the relay is located. I replaced the fuse also just to be in the safe side.
stig009
Apr 16, 2018 05:33 PM
pmcortez
Jan 30, 2017 05:05 PM
Troop4Christ
Jun 26, 2012 06:08 PM
Reidicus
Feb 4, 2012 10:04 AM
hang10
Mar 3, 2008 07:15 PM
