Brake pedal sensor
Old Dec 21, 2016 | 08:11 PM
T_Cooksey88's Avatar
T_Cooksey88
Brake pedal sensor
Brake pedal drops a small amount when started and the brakes will stay on unless I use my foot to pull it up or if I am pressing the gas when accelerating it pushes it up. I've turned the screw out more and more but it's never enough
Old Dec 21, 2016 | 09:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ck vacuum at the power brake booster. Take the hose off at the plastic 90 fitting, it can break if you try to remove it from the booster body.
Sounds like time for a new power brake booster. What screw are you adjusting?
Old Dec 22, 2016 | 07:37 AM
F250_Super_4X4's Avatar
F250_Super_4X4
Like 77&79 said but also ensure the plastic fitting, which also serves as a check valve, is operating. This sounds wrong but, suck on the portion that goes into the brake booster, it should not flow, now blow, there should be free flow. Also check for any vacuum leaks.
cwesner227
1983 - 2012 Ranger & B-Series
Sep 9, 2014 12:55 PM
Elk4me
Jun 15, 2014 10:07 PM
deltajuke
Mar 19, 2013 06:25 PM
LTCPipkin
Aerostar
Oct 28, 2007 08:56 PM
MrPleasant
Feb 4, 2002 10:57 PM
