2005 F 150 problems ???h
Old Dec 21, 2016 | 05:45 PM
Hunt77's Avatar
Hunt77
2005 F 150 5.4 197,000 miles. I was driving down the road and it just died, no check engine light, towed it home and put scanner on and got p2106, p0222, p2104, p2107, p2110 and p2135. I ordered a new throttle body put it on and engine will turn over and won't start ??? Any suggestions ??
Thanks in advance
Old Dec 22, 2016 | 10:29 AM
redfishtd's Avatar
redfishtd
Throttle body problems
My 05 had this problem and I replaced throttle pos sensor but it still was intermittent. The short of it was I had a throttle body model that was flagged as a bad series model number . So I got an oem updated off ebay and it came with everything on it reasonable and that was 70k miles ago .
I don't have those numbers right now but I think you can find them on here . It has a circuit board on motor that decodes signal ,it is quite complicated so the whole assembly needs to be replaced .
Old Dec 22, 2016 | 10:32 AM
redfishtd's Avatar
redfishtd
re-read your message
maybe fuel module problems above spare tire corroded ?
Jebs
Modular V8 (4.6L, 5.4L)
Jan 16, 2015 06:28 AM
rotten65
Mar 23, 2014 01:15 PM
026TB4U
Apr 29, 2012 09:14 AM
horseracer58
Modular V10 (6.8l)
Dec 21, 2009 02:05 PM
w7wv
2004 - 2008 F150
Nov 8, 2007 01:24 AM
