FUEL PRESSURE??
Old Dec 19, 2016 | 09:25 PM
Oldblue78's Avatar
Oldblue78
FUEL PRESSURE??
Put an inline electric fuel pump on my 78 f-150, motor is a 400 and the carb is a 2 barrel motorcraft 2150 I believe. Anyone know what pressure to set the fuel pressure regulator at? Thanks a lot.
Old Dec 19, 2016 | 10:09 PM
captainwoot's Avatar
captainwoot
Hello, I would think around 5 -6 lbs should work..
Old Dec 19, 2016 | 10:53 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Well, 5 psi seems like it is ok, but I will look in manual and verify and follow up tomorrow.
Old Dec 20, 2016 | 02:41 AM
Ozzie H.'s Avatar
Ozzie H.
I don't have the '78 shop manual. The '77 manual, for that engine, says that the static pressure for the mechanical pump should be 6.0 to 8.0 P.S.I. with temperatures "normalized", curb idle speed, in neutral. Volume flow should be a minimum of 1 pint in 20 seconds.
Old Dec 21, 2016 | 09:14 AM
COFLHTK's Avatar
COFLHTK
78 shop manual says the same thing.
Old Dec 21, 2016 | 12:08 PM
DeepRoots's Avatar
DeepRoots
Shop Manuals aside....
A good rule of thumb based on my own experience:
-center hung float can handle 7psi max
-side hung float can handle 5.5psi max
Old Dec 21, 2016 | 07:24 PM
Blue and White's Avatar
Blue and White
6-8 PSI sounds good with a Motocraft (or Holly) carb. 9 psi may be OK but no reason to push it.
Edelbrock carbs need under 5 psi.
studaddy
Nov 25, 2017 05:28 PM
79f100six
Nov 6, 2007 08:11 AM
79f100six
Jun 8, 2007 07:31 AM
79 sb150
16
Jan 1, 2006 08:00 AM
timjk69
Mar 27, 2005 10:46 PM
