Courtesy light wire tap
Old Dec 17, 2016 | 06:47 PM
Jhndere's Avatar
Jhndere
Hey folks! New member here! I have a 2017 F250 Lariat Super Cab Diesel. I installed Big Rig Ice lights last night but haven't hooked up the white lights yet as I'm looking for some input on what wire I should tap into to tie into the interior light or puddle lamps. Thanks!
Old Jan 26, 2017 | 06:09 PM
Jonathan Gofigan's Avatar
Jonathan Gofigan
Big rig ice
Hi there,
I have a 2017 SD f250 I am trying to install the big rig ice on the truck but my headlights are the leds type what wires did you tie at head light ?
Old Jan 26, 2017 | 09:50 PM
Jhndere's Avatar
Jhndere
Jonathan, I removed the headlights... PITA. You have to take the entire front grill out. Then, I peeled back the tape wrapped around all the wires feeding into the bulbs. I then tapped into those wires with everything but the ice light... still waiting to figure out what wire to use for that. But all my yellow lights work.
Old Jan 26, 2017 | 10:03 PM
Jonathan Gofigan
Yes that was a pain to do all that just to get headlight out. My headlights are not the bulbs type it has one plug leds. Also I hook the big rig ice on my 2013 ford f150 I think I wired the White wire into the side parking bulb wire try that because it will do the same thing like the cargo and puddle lights.
blues_man_in_pa
Electrical Systems/Wiring
Jan 21, 2009 05:10 PM
ricochet
Oct 28, 2007 11:28 AM
colad
1978 - 1996 Big Bronco
Aug 24, 2007 02:37 PM
el conquistador
Mar 3, 2006 04:58 PM
felixr
Feb 27, 2006 10:35 AM
