Sponsored by: Real Truck
Do I really need a diesel?
Old Dec 14, 2016 | 09:26 AM
Firefighter 1406's Avatar
Firefighter 1406
Simple answer. Heck ya everyone needs a diesel!!!!
Real answer always depends on how good you are at maintenance, what do you pull, short drives verses long drives. Ultimately your choice.
Old Dec 14, 2016 | 09:33 AM
john hardy's Avatar
john hardy
You don't need a diesel. I had a 6.0 it was a piece of crap! I would never buy another diesel after my experiences with them. Get a v10 with deep gears and you'll be fine.
Old Dec 14, 2016 | 10:00 AM
benjamin247's Avatar
benjamin247
Originally Posted by WE3ZS
To the OP, if you decide to look at gas rigs I would skip the '99s and look for a '00+ 2V V-10 as they have a little more power. BUT the most important thing to find for heavy towing work is the deeper gears behind the gas motors, try to find a gasser with 4.30s to make pulling a heavy trailer much easier.
Try to narrow down the trailer choices to have a solid weight range to match a used truck to, or buy a truck then find a trailer that fits within the trucks ratings.
This is totally gonna bust me out as a newbie, but I have been seeing 3v or 2v references. What does that mean?
The truck I am considering buying (if all checks out with purchase inspection by a diesel mechanic) is a 1999 7.3L Diesel (manual, 4wd, 218k miles) for $8K.
After looking at some trailers, I plan on getting a trailer that is GVWR of 10K lbs or less.
Old Dec 14, 2016 | 10:07 AM
Diamnd1's Avatar
Diamnd1
2 or 3 valves per cylinder. 99-2004 V10 has 2 valves per. 2005+ has 3 valves per. 3V has a significant power improvement.
Old Dec 14, 2016 | 10:12 AM
benjamin247
Good to know. Thanks!
Old Dec 14, 2016 | 10:37 AM
akorcovelos's Avatar
akorcovelos
OP is looking at 7.3s, night and day compared to a 6.0. You bought the worst diesel ever made, no surprise your jaded, but the 7.3 is a different animal.
OP, for 100 miles per month, get a gas truck. Diesels (and Superduties in general) don't like to sit. You will have more issues with a truck sitting weeks at a time than one worked everyday. Also, a 7.3 with 218k has a long life ahead of it if properly maintained. The same age truck with a gas motor, and likely similar mileage, will require engine overhaul sooner if all upkeep is equal between the two.
That said, I'll always own a diesel after having one. I had gas trucks in the past, and they have their place, but a diesel just makes any work seem so effortless. Yes, maintenance is more, fuel is more, MPG is around the same or slightly better, but if you pulled with one you would immediately understand why they win out in hauling/towing applications.
Old Dec 14, 2016 | 10:43 AM
john hardy's Avatar
john hardy
Yes the 7.3 is a good motor. 6.0 and 6.4 not so much.
Old Dec 14, 2016 | 10:50 AM
don123's Avatar
don123
You could get a 7.3 they are very reliable. Since you only tow 100 miles a month a gas v10 would be fine. v10's have spark plug issues though.
Old Dec 14, 2016 | 10:57 AM
finn's Avatar
finn
I bought a 2005 V10 F350 crew cab dually as a more or less dedicated tow rig for a 13000 lb fifth wheel camper last summer. Paid $4500 for it with 140k mile I just drove it 1500 miles from Michigan to Texas.
performance was good. It downshiftsto fourth and even second on one occasion, but maintained an entirely adequate speed, even with 3.73 gear I averaged 8 MPG over 1500 Miles, but with gas less than $2.00/gallon, the fuel mileage still made for a cheap trip.
If I drive this thing 6000 miles/year, a diesel would never pay off.
Old Dec 14, 2016 | 12:59 PM
akorcovelos
not sure I agree. I pull a 10k (loaded) 35' bumper pull and average 12-13mpg, at 8-10mpg with the gas equivalent the Diesel is a better deal IMO. Diesel, at least here in the Midwest isn't that much more than gas.
Old Dec 14, 2016 | 01:10 PM
apappal's Avatar
apappal
Well, if you never had one you won't notice the difference. I went from a diesel to the 6.2 and it was the worst decision I ever made. I hate the performance and I hate the truck. Only reason I bought was the good deal I got on, If I could go back, I would not have made the deal. Just my opinion.
Old Dec 14, 2016 | 02:08 PM
WE3ZS's Avatar
WE3ZS
What gears does your 6.2 truck have, one must do one's homework........gas rigs need the deeper gears to get the heavy work done well. Not saying that the gas truck will ever be equal to the PSD in pure power & torque but comparing the towing performance of a gasser with high gears vs one with low gears is almost night and day.
Old Dec 14, 2016 | 02:15 PM
  #28
akorcovelos
The problem with deep gearing in a gas truck is daily drivability. What RPMs are you running at unloaded highway speeds (70-80mph)? Seems like that V10 would be screaming and guzzling gas with those gears at higher speeds.
Old Dec 14, 2016 | 02:21 PM
  #29
RV_Tech's Avatar
RV_Tech
With a truck dedicated to towing as the OP said and with so few miles per month, mileage may not be an issue.
Old Dec 14, 2016 | 02:33 PM
  #30
apappal's Avatar
apappal
It has the 3.73, for me its towing, I've had to learn how to drive a gas truck. Throttle response sucks, almost got T-Boned twice, stepped on the gas and nothing for probably 2-3 seconds. Ergonomics of the audio and steering wheel controls leave a lot to be desired as well. I read a lot about the 6.2 here and everyone loves them. For me no way. Truck has a plow package which I do plow and live in the NE, guess what when the Windshield Washer is low it doesn't tell me. Along with some bad experiences with the dealer = I hate this truck. I would trade even for my old truck back and even keep the payments. Believe me I know I'm comparing apples to oranges with diesel and gas. But to go from a 10 year old truck , it had more user friendly controls and it told me when the WW fluid was low. Sorry for the rant.
