76 Highboy Running without a bed
Old Dec 12, 2016 | 10:30 AM
mlacek's Avatar
mlacek
Trailering
Hey guys, I'm new here - thanks for all the help. My son and I are restoring a 76 Highboy (yes, we've verified it's a true Highboy) and the bed was rusted out so we'd like to run it without the bed for awhile. (Real HighBoy beds are hard to find, so we're thinking it might be awhile!)
My question is, does anyone have any recommendations for how to wire some taillights, etc without a bed? And this one has an aftermarket? supplimental gas tank between the framerails that we'd like to also use. I figured I'd just fabricate a temporary cap with a PVC cap or something...
Any advice would be greatly appreciated!
Old Dec 12, 2016 | 11:02 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ck what you local PO say about running around with no bed. Tail lights bumper mounted or not. Maybe a great time build wood flat bed. Also with that 400 lbs ish off the back end it will almost traction less.
No bed ='s great way to bust out a back glass.
Here's what the factory wiring diagram says for rear lights:
Blk/rd= backup lights
Black= side marker, tag lights (on styleside)
Brown=tail lights, tag light (on flareside)
green= RH stop and brake
Yellow/blk= LH stop and brake
Rear light wiring #2
BROWN: running light circuit
YELLOW with BLACK stripe: driver-side stop/turn
GREEN: passenger-side stop/turn
BLACK with RED stripe: backup lamps
73 & 79 headlight-marker lights use same color codes
Brown= side marker and parking lights
White-blue trace= turn signal
Red-black trace= Low beams
Green-black trace= Hi beams
Black=ground
Flat bed wiring…
Brown= Run Light
Green= Brake light- L
Yellow= Brake Light- R
Black= Reverse Light ??
Old Dec 12, 2016 | 11:30 AM
mlacek's Avatar
mlacek
Trailering
Thank you!
Old Dec 12, 2016 | 11:32 AM
Earnie Rosenow's Avatar
Earnie Rosenow
I know of a rot free bed on an f250 highboy with trashed sides=it is in a wrecking yard on hwy 3 headed twds gorst here in Washington state
Last edited by Earnie Rosenow; Dec 12, 2016 at 11:33 AM. Reason: forgot to say it is a highboy
Old Dec 12, 2016 | 11:41 AM
gittinwidit's Avatar
gittinwidit
Got one for sale in NC. Would probably cost more to ship than actual cost though.
Old Dec 12, 2016 | 11:45 AM
mlacek's Avatar
mlacek
Trailering
I appreciate that, guys - but I am in Utah.
Old Dec 12, 2016 | 11:51 AM
gittinwidit
I ran my 76 without a bed while I restored it and picked up like 2 MPG. I just used a complete trailer wiring kit and duct taped it on. This was only for 3-4 weeks.
But if you get off the road, you're spinnin...
Old Dec 12, 2016 | 11:53 AM
Jarrett Campbell's Avatar
Jarrett Campbell
You could get the magnetic tow lights. They plug into a 4 pin trailer plug and mount on anything metal. I used a set to tow my high boy back from Oregon and they worked great.
Old Dec 12, 2016 | 11:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mlacek
Hey guys, I'm new here - thanks for all the help. My son and I are restoring a 76 High Boy (yes, we've verified it's a true Highboy) and the bed was rusted out so we'd like to run it without the bed for awhile.
Real High Boy beds are hard to find, so we're thinking it might be awhile!
8' Styleside bed is the same 1973/76 F100/350 Regular Cabs (except F350's on the 140" wheelbase), but...
High Boys have different bed mounting holes due to their 33 1/2" inner frame rails behind the cab.
Old Dec 12, 2016 | 06:20 PM
krazyness's Avatar
krazyness
Don't know about Utah, but in Washington state you don't need a bed as long as you have some sort of "fender" covering the tire and mudflaps that hang down to centerline of the axle. Only time I've ever been harassed about mud flaps was in my lifted jeep though even though my truck has more exposed tire than the jeep.
Old Dec 12, 2016 | 07:49 PM
Blue and White's Avatar
Blue and White
A set of generic trailer lights mounted on the rear frame rails will help and also provide a bracket and light for the license plate. These are typically $15-$20 at an AP, home improvement or farm supply store. These need to be tied into factory wiring per recommendations above.
I have run around this way using a piece of wood mounted on the end of the frame rails for light mounting. If you do use wood to mount, the mounting studs for the lights will need a ground wire to the frame.
Later, when I built a wood flatbed, I used the same lights permanently mounted and no problems.
Old Dec 12, 2016 | 08:08 PM
burnthelight88's Avatar
burnthelight88
That I am aware, all states legally require an actual rear bumper to be legal.
Old Dec 13, 2016 | 07:38 AM
gittinwidit
Not all of them. :-) NC doesn't require bumpers on a restoration. I contacted NCDMV and asked. Nor rear fenders.
But there's not a state line I can cross legally like that.
Old Dec 13, 2016 | 03:40 PM
77&79F250's Avatar
77&79F250
Running no bed is a great way to get the back of the cab a little dirty....lol
Old Dec 13, 2016 | 07:49 PM
FuzzFace2's Avatar
FuzzFace2
Rear bumpers were an option on the truck right? It has only been last few years they are from the factory.
I also don't know of any state that you have to run rear fenders.
If that was the case then 18 wheelers could not bobtail, no trailer, down the high way.
Only thing like said is mudd flaps that come down lower than the center line of the wheel
What was posted using cheap trailer lights is the best way to go.
Run a 2x4 across the back to mount mudd flaps & light to and enjoy.
And yes the back of the cab will get dirty and rocks stuck in the tread can take out the back glass.
Depending on the size of your tires maybe use a 55 gal drum to make fenders to cover the wheels with mudd flaps just incase.
Dave ----
