Well I could use some help
Old Dec 8, 2016 | 03:46 PM
luckstur's Avatar
luckstur
Hey all. So I'm stuck in the middle of the city right now. I have a 1997 7.3l f350 auto. Had my interview for the forces this morning. Went good. But got back to my truck and tried starting. Was a no go. Cranks fast but doesn't fire. Doesn't blow much white smoke out the tailpipe either. I tried to jump the glow plugs but it's like the post has no connection what so ever. So researching people say could be a bad wire to or from the pcm. I know my glow plug relay isn't working because it used to buzz but now it doesn't. Hoping it's not my pcm. I have a couple friends coming to help me load my truck on a trailer. But this is my only vehicle. Need to get it running fast. It was pretty cold today and someone said their diesel jelled up. So I open my fuel bowl up to check seemed fine. Anyways, truck turns over fine but won't fire wondering what I could swap that might help. I have a wrecked truck same year at home I can pull parts from but it's a manual thanks.
Old Dec 8, 2016 | 04:21 PM
farmert's Avatar
farmert
When you first turn the key to the run position, do you get a wait to start light?
Old Dec 8, 2016 | 04:23 PM
luckstur's Avatar
luckstur
Yeah. It stays on like I forgot to plug it in so it's taking a bit longer to go off. And when it goes off it kind of flutters on and off really fast just once though.
Old Dec 8, 2016 | 06:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
So in the morning starts ok and when it is warm or hot, does not?, maybe you have bad IPR o-rings.
Old Dec 8, 2016 | 06:45 PM
luckstur's Avatar
luckstur
No no its started up great until today. Sat over night and now won't start.
Old Dec 8, 2016 | 06:54 PM
79jasper's Avatar
79jasper
Sounds like the fusible links to the gpr burnt out.
Old Dec 8, 2016 | 06:55 PM
luckstur's Avatar
luckstur
Would that cause me too not be able to jump the glow plugs?
Old Dec 8, 2016 | 06:59 PM
79jasper's Avatar
79jasper
Yes. They connect at the starter Solenoid on the fender.
Old Dec 8, 2016 | 07:00 PM
luckstur's Avatar
luckstur
I thought the glow plug relay was on top of the valley of the engine
Old Dec 8, 2016 | 07:01 PM
79jasper's Avatar
79jasper
Yeah, I said starter Solenoid. That's where the gpr gets its power from.
Do this: Trace the power wire from the gpr and tell me where it goes.
Old Dec 8, 2016 | 07:06 PM
luckstur's Avatar
luckstur
Oh I see what you're saying, the gpr gets power. The red wire is hot all the time I can't get any power from that to the glow plugs. It's like the glow plug wires on the other big post of the gpr aren't connected to anything but I know they are. There isn't a fuse built into the harness for the glow plugs is there. I tried running a wire from gpr power post to the glow plug wire post and nothing happened.
Old Dec 8, 2016 | 07:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Here is a good reading for you. I hope you can open it good luck. :
File Type: doc
Old Dec 8, 2016 | 07:37 PM
luckstur's Avatar
luckstur
Thanks I'll give it a read! I slapped her on a friend's trailer started it with ether
Old Dec 8, 2016 | 08:38 PM
97-psd's Avatar
97-psd
It's a fusible link, there won't be an inline fuse per say. Double check the fuses in the box. Does the tach move while cranking? If no success try bypassing the current power supply by running a hot leg from the battery to the gpr then give it a crank. Don't leave it there just do the same thing as if you were jumping the gpr with a screwdriver
Old Dec 8, 2016 | 09:05 PM
luckstur's Avatar
luckstur
I tried that as well didn't do anything I go it started with ether to get it up on a trailer. Taking it to my friends workshop to pull the valve covers off. Make sure we connected the harnesses properly from changing them last weekend.
