Time for brakes
It's time for new brakes. Got 95K out of the factory pads/rotors! I think that is good at least. I am planning on getting Ford pads since the originals lasted so long. I tow fairly heavy, 10K+ on the CO mountain passes. i believe in having the trailer brakes adjusted properly and using the engine and gearing to brake, hence I got a lot of miles out of the brakes even towing on these passes. I've been fairly happy with the originals, albeit I always thought the truck didn't stop as fast as it should when everybody in front of me slams on their brakes, so I wouldn't mind a bit more stopping power. I've always chalked that up to these trucks are just heavier than my Honda.
Anyway, you guys recommend any other pads as being better than the originals? How do I know which pads came on the truck? I'm guessing BR-1069 and thinking about bumping up to the BRSD-1069's or should I go to . the Standard Premium BRF-1438? Should I just go ahead and plan on replacing my rotors or try and have them turned at Napa? Recommendation on replacement rotors or just stick with Ford's? Also, I usually bleed the brakes when I do new pads. Recommendation on brake fluid? Normally I just pick up the Valvoline Dot 3 and 4 fluid at wally world. Is that good for this truck?
Any surprises or special tools when doing the brakes on these trucks? i've done brakes numerous times on other cars/trucks.
I've found that the Ford rotors work out the best, never turn the rotors only replace, always torque the wheel lugs progressively increasing the pounds in an alternating pattern - Then re-torque after a few hundred miles to prevent the rotors warping.
I'm sure Jack will weight in with some pointers
https://www.amazon.com/Permatex-2412...SXTFNG26FCNDVN
The '05 and up got the TRW calipers over the older Akebono, with different pad design and material. The OE product was a very good overall material. The SD Motorcraft lineup unless they changed the formula gets you a hit the bit more in friction.
Unless you are going to have the rotors turned on the truck with an on-car lathe, I don't recommend turning at any parts store. My old company, and in conjunction with Ford, did a study showing less then spectacular results for rotor finish and machined in runout. After that study even Ford Corporate had the dealers get their act together as tooling changeout makes a big difference even with the on-car lathes.
Myself, if the rotors exhibit no pulsation or surface issues, they stay as they are, or I get new rotors, assembly line preferred or Motorcraft secondarily. Slots and holes for me are a no-go.
Higher friction pads will reduce pedal force, but tend to come at the expense of lower friction without being warmed up. That can be an acceptable compromise, but not acceptable off the assembly line, both for customer test drive off the lot and internal stopping distance targets. For my older truck with the Akebono calipers, I used to use Performance Friction Z pads myself until they changed the formula, now use Hawk LTS.
Otherwise asking for what brake pads and rotors will quickly get you into a very subjective feedback loop.
Extensive work was done on Superduty calipers to prevent brake fluid boil, and all testing was done with aged brake fluid to a specific moisture content so that DOT 3 was the standard. Dot 4 gets you an initial higher boiling point, but comes down quicker and in a few years will be the same boiling point. You can use either, but changes in the two to three years time period is the best choice no matter what fluid. And today there is a lot of specialty fluid being sold to bump market share. The SD's brake hydraulics were all developed with standard DOT 3, FYI.
All I know is, every manufacturer of rotor that I tried (drilled/slotted/crio/normal) resulted in un-even and varied thickness wear while I lived in CO - The only time I've had decent life on the rotors is when I've used Ford rotors. Though I'm certain my problem is the weight of my feet, too heavy on both go and stop pedals. LOL
Thanks
Thanks
Runout by torque very vehicle dependent, by wheel, rotor and hub design. I get hyper about the use of the word warped because it has led in the repair industry to the wrong understanding of the pulsation development. A few hundred thousands of miles testing has shown it brake-off wearing of the high runout areas, pulsation with thermal induced hard spotting, and with that you can't machine it out. The next 5-10k of driving the hard spots do not wear down and pulsation reemerge due to thickness variation. But the mechanic tells the customer it heat warping from thin rotors when it's not.
Unlike other manufacturers in their service parts, and much more so then aftermarket parts, Ford keeps a tight spec on the rotor machining, even with the Motorcraft aftermarket rotors. It's all about the runout and installed runout. If it's a Ford, I buy OE first, Motorcraft if OE not available.
Back to cuttin.
Back to cuttin.
Rotor part numbers are 5C3Z-14300-CA paid $73.79 ea
