1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Flaky steering wheel controls 2004 Navigator
Old 12-05-2016, 07:37 AM
MackGuy's Avatar
MackGuy
MackGuy is offline
Hi all,
One of the minor but fairly annoying traits I've noticed in our 2004 Navigator (Ultimate, without Navigation) is that the steering wheel controls seem to have a bit of a mind of their own.
For instance, sometimes the volume button will skip to the next cd track. Sometimes the temp button will adjust the fan, sometimes the mem button does a source change. Sometimes cruise control doesn't want to set etc.
Anyone have a similar issue and have any idea how to resolve?
Old 12-05-2016, 09:16 AM
Skauber's Avatar
Skauber
Skauber is offline
Perhaps dirty contacts? These buttons work on varying resistance principle. I.e. when you press Fan up button, the circuit shows 300 ohms, but when you press Mem it will show 400 ohms, and so on. (values are only for example, not the actual values). So a dirty contact might present a different resistance, and be misinterpreted by the PCM or system.
Remove the buttons, and clean the contacts would be a good thing in this case. Depending on your skill level, perhaps verifying that the resistors have good contact and are in spec could be a step to take as well. The switches aren't cheap, so definitely worth to attempt to repair the ones you have.
Old 12-05-2016, 09:29 AM
MackGuy's Avatar
MackGuy
MackGuy is offline
How do you remove the switches? Dirty contacts is what I was thinking...
They all work, just sometimes they don't work as intended... sometimes they do lol. Just a lottery on whether it does what I think it will.
Old 12-05-2016, 02:24 PM
Skauber's Avatar
Skauber
Skauber is offline
I believe it's pretty much the same as the Expy, which means you remove the drivers air bag module (power down and discharge the system properly first!) and the switches can easily be removed.
Old 12-05-2016, 02:48 PM
MackGuy's Avatar
MackGuy
MackGuy is offline
Thanks, I have the factory service manuals on the way, so hopefully they cover everything in detail.. Haven't removed an airbag in some years!
Old 12-05-2016, 02:50 PM
Skauber's Avatar
Skauber
Skauber is offline
Yeah, that'll tell you all you need to know, including how to safely power down and discharge it before touching the airbag..
vacuumbed
01-29-2016 06:06 AM
drakerc
06-13-2015 09:59 PM
TheMilkman00
06-23-2011 08:27 AM
jerzydiver
11-05-2006 10:34 PM
Quick Reply: Flaky steering wheel controls 2004 Navigator
