Fixing elec door locks
Old Dec 9, 2001 | 02:53 PM
FAL's Avatar
FAL
The rear elec locks on my 90 crew cab failed.
Took them apart and fount they operate by a little elec motor that spins a hollow ended shaft with three small holes with thiny ***** that fit is spiral groves on the acutator rod and thus force it up and down depending on direction of motor spin.
Called ford got high quote for part.
Went to salvage yard got a couple off a lincon for $6 each. Exactly same only acutator rod is different. So just poped of the clip removed the 3 ***** and swapped the acutator rods. Then replaced the ***** and clip ring and good to go.
Works great and much cheeper the buying them from ford.:7
Old Dec 21, 2001 | 11:13 AM
EaSTxCOwboY's Avatar
EaSTxCOwboY
Old Dec 26, 2001 | 04:33 PM
yupduff's Avatar
yupduff
>motor spin.
I am trying to remove the electric actuator that is mounted inside
the door panel that operates the power door lock on my 95 F150. Do you have any suggestions on how to remove the unit for replacement/testing?
Old Dec 26, 2001 | 04:53 PM
kioolt's Avatar
kioolt
I don't know for sure about your truck but on earlier Ford vehicles that I have worked on, the door lock actuator mounts with a single screw that is easily accessible on the door jam below the door latch. I can't remember how the actuator attaches to the door latch.
Old Dec 26, 2001 | 05:45 PM
yupduff's Avatar
yupduff
Kioolt,
Yes the actuator is mounted on
Instead of a screw there is a round
disk with what appears to be the
threaded end of bolt sticking through
the center of it. At first I thought
it was a tamper proof TORX screw. Inside
it is round along with the outside edge.
Hopefully it does not have to be unscrewed
from the inside. Any suggestions?
Thanks
Old Dec 26, 2001 | 06:26 PM
kioolt's Avatar
kioolt
I went and looked at my 93 F150XLT to see what you are talking about. Then I went and got my Helm's manual.
1. Remove door trim panel.
2. Remove actuator motor and swivel bracket assembly from the door by drilling out the retaining pop rivet.
Installation involves replacing drilled out pop rivet with a new one.
Old Dec 26, 2001 | 06:34 PM
yupduff's Avatar
yupduff
Thanks for the investigative research.
Why would Ford use a pop rivit and not
a screw like on the rest of the door
components? That is one large pop rivit.
I am going to give this some thought
before I start drilling into the side of
my door.
Thanks again,
Bob 1995 F150
Old Dec 26, 2001 | 08:58 PM
nitro94's Avatar
nitro94
I find it easier to grind the head off with a die grinder and then replace the rivet. It does take a special rivet. The rivit gun cost me $200 from Snappy but it will do all of the various rivits found in todays doors.
Old Dec 27, 2001 | 09:12 AM
yupduff's Avatar
yupduff
Thanks for the information on the
best way to remove the rivit. Sounds
like the cost of tools and supplies
will be about the same as having the
Ford dealer do the repair
Old Dec 27, 2001 | 06:50 PM
FAL's Avatar
FAL
It is easy to drill or grind.
Some have a metal disk with a snap ring holding it to a plastic bracker some have a solid metal bracket but all have the rivit.
Easy at home hard without power tools at pull u parts.
Once off easy to put one the the after market threaded blind nuts (like used for roof racks) into the old hole in the bracket then it is a screw on affair from then on.
A kit with about 20 of each size blind nut and nut plus allen wrenches for install is only about $20.
If it has the metal bracket easy to bend ears apart and slide out acutator without removing tha bracket.
Acutator just has pin on each side slid into rubber gromets in U shapped bracket so that is can swing for alingment.
smith1000
Aug 12, 2013 06:18 PM
skidmarks82
Montana Chapter
May 3, 2009 04:11 AM
Ithaca
1997 - 2003 F150
Mar 29, 2008 09:50 AM
hc130flyboy
Jan 18, 2005 07:56 PM
