Intake help needed
Old Aug 25, 2003 | 04:45 PM
bigblu's Avatar
bigblu
Question Intake help needed
I have to smog my 78 f-150, but have run into problems. I live in California. It's an out of state truck,so it only requires egr for visual.
I have an edelbrock 4barrel intake, and a 600 cfm 4 barrell carb. The problem is we don't know the original egr valve for it.
We called edelbrock,who said use a spacer, and throw on a 75 egr valve. it doesn't work with it. It runs much rougher with the spacer, and runs perfect without it. It's drawing air from the front venturies, which is not supposed to. But, when mounted, the spacer plate overlaps the sealing lip,thus,causing a massive vacuum leak. This edelbrock intake is designed with an egr provision built into the back of the intake, ie the egr mounts directly behind on the intake behind the carb.
Our options are
1) find a factory 4 bb intake for a 75-79 351/400 (I've tried everywhere today)
2) track down the right egr valve (over 300 listings for a 75 only)
3) pull the 4 bb, and revert to the 2bb.
If anyone could shine some light on this, I'd be forever grateful!!
Old Aug 25, 2003 | 05:16 PM
bubbaf250's Avatar
bubbaf250
Intake help needed
There are no factory 4V intake manifolds for the 351M/400 engine because they were never factory equipped with a 4V carb. Therefore, you will have to at least get a 2V-4V adapter and switch to a 2V carb to pass CA emissions.
The EGR valve should be mounted to the manifold directly, with no spacer under the carb (except the 2V-4V adapter). Apparently the tech guys at Edelbrock didn't understand which manifold you had.
Check this page for the correct EGR valve part number for your truck:
http://home.earthlink.net/~bubbaf250/parts/parts05.html
BTW: if the EGR valve part is obsolete from Ford, you can use the Ford part number to cross-reference the correct aftermarket replacement.
Old Aug 26, 2003 | 12:06 PM
bigblu's Avatar
bigblu
Intake help needed
Well, Edelbrock said we'd just need an adapter to bolt the egr to the intake. The problem is finding an egr that the center to center bolt hole is 3".
We've been on the phone all morning, and haven't had any luck.
Old Aug 26, 2003 | 12:54 PM
beartracks's Avatar
beartracks
Intake help needed
Originally the engine came with a 2V, a plate under that with the vacuum diaphram mounted on the back. With a 4V manifold you would have to use the 2v carb on an adapter with the factory plate in between.
The only other option I know of is to replace the manifold with the EGR version of the same thing. It has the boss and passages built in.
