Deck Clearance
Old Aug 23, 2003 | 07:27 PM
danlee's Avatar
danlee
Deck Clearance
What is the deck to piston clearance on a stock 400?
Old Aug 23, 2003 | 09:49 PM
bubbaf250's Avatar
bubbaf250
Deck Clearance
Spec is 0.0565", but I've seen as much as 0.0670", depending on the pistons.
Either way, it's way too much.
Old Aug 26, 2003 | 10:39 AM
nasty77f150's Avatar
nasty77f150
Deck Clearance
my 351m is .040 in the hole. i thought about decking the block to raise compression, but then all that throws the geometry off.
Old Aug 26, 2003 | 01:11 PM
danlee's Avatar
danlee
Deck Clearance
You can deck the block to raise compression, but you have to compensate for the change in geometry by removing something from the intake side of the heads, or the intake manifold. I don't know what the formula is, but 1/2 comes from each side.
