Best Steering Wheel Control Integration Module
Old Nov 30, 2016 | 05:20 PM
chrison600's Avatar
chrison600
Hi all,
I'm in the process of planning a head unit swap in my 2001 X and need to find a good (the best?) integration module for our steering wheel controls. I think there are basically two to choose from, one by PIE and another by iDatalink.
Any feedback as to which works best?
The likely head unit will be a Pioneer.
Chris
Old Nov 30, 2016 | 05:27 PM
lightflyer's Avatar
lightflyer
Check with Metra products. They make all kinds of adapters and such for this.
This is the one listed for mine.
http://www.metraonline.com/part/ASWC-1
Old Nov 30, 2016 | 06:03 PM
william_04_x's Avatar
william_04_x
Whatever you get, make sure it's compatible with both the HU, and vehicle. Pioneer is so popular you shouldn't have a problem.
I installed a PAC interface to control my Clarion HU. I like that fact you can program tap, and long press commands for each steering wheel button(ie: short press "mode"=change input source/ long press "mode"= power on/off. That effectively doubles the amount of available commands you can potentially initiate with your existing wheel buttons.
Old Nov 30, 2016 | 07:17 PM
timf150's Avatar
timf150
I am subscribing to this thread as I just picked up a Navigator steering wheel to swap into my Ex and want to use the steering wheel controls with my Pioneer stereo.
I was doing some reading on the steering wheel adapters. I have not decided on any one but I did like the one from Axxess.
Axxess Integrate, Comprehensive Interface Products
Tim M
Old Nov 30, 2016 | 07:30 PM
timf150's Avatar
timf150
That seems like a cool feature, its going to be nice to hear from those that have installed any of these products.
Tim M
Old Dec 1, 2016 | 06:14 AM
Aaron_Jones's Avatar
Aaron_Jones
I just installed the Axxess-ASWC-1 in my EX to use with my Pioneer AVH-X4800BS. It works well. It auto detects your unit for you so you do not have to program it.
Three wires total to hook up! You have to hook up 12v, Ground, & Connect the Gray/Red wire of the ASWC-1 to pin 14 of the vehicle's 5700 Harness (steering control harness).
Install instructions
Thats it!
I hope that helps...
Old Dec 10, 2016 | 05:03 PM
lightflyer's Avatar
lightflyer
The unit I just installed didn't even need the adapter. The radio had the ability to program the buttons.
Head unit went in today. Didn't connect cameras yet though. Ended up not using any mounts at all due to the tight fit. No face plate either. The steering wheel control adapter also wasn't needed with this radio. The button pushes are programmable in the head unit itself. It looks like it was made for it.
Old Dec 10, 2016 | 05:20 PM
BigGreenEx's Avatar
BigGreenEx
Do these adapters allow for use of the steering wheel controls and the rear console controls?
Old Dec 10, 2016 | 08:01 PM
william_04_x
That looks great! Nice feature that the adapter isn't necessary.
Old Dec 10, 2016 | 11:58 PM
Watcher58's Avatar
Watcher58
Hope you have better luck than I. Axxxess should be the easiest. Didn't work for me. Tried a PAC-that didn't work. Wore out tec support on both and never got anything resolved. I put in a new Kenwood DDX 9702S. I finally ordered a remote control for older Kenwood units. I get most functions that way--well all the ones I would get on the steering wheel. It might be the Kenwood unit. This is the 2nd X Ive tried this in and couldn't get the controls to work in either one. The Axxess would go through and say it had program and best I ever got was "volume up". PAC wasn't even close. Of the 2, the Axxess was the easiest--in theory
Old Dec 13, 2016 | 07:20 PM
chrison600's Avatar
chrison600
Originally Posted by Aaron_Jones
I just installed the Axxess-ASWC-1 in my EX to use with my Pioneer AVH-X4800BS. ...You have to hook up 12v, Ground, & Connect the Gray/Red wire of the ASWC-1 to pin 14 of the vehicle's 5700 Harness (steering control harness).
Did you use a 12v mid-wire tap to get the feed from pin 14?
Are you able to control phone call volume from the steering wheel?
Chris
Old Dec 17, 2016 | 06:44 PM
chrison600's Avatar
chrison600
How much did you trim the upper/lower lips of the opening? I was trying to mock things up today and was tentatively planning to trim the lower down on the left and right to make it level with the mid-edge/lip, then trimming upper as needed to clear the chassis.
That seemed to be a decent way to center the head unit in the opening vertically...
Chris
Old Dec 18, 2016 | 05:56 PM
lightflyer's Avatar
lightflyer
I had it done so can't really say. IIRC he trimmed the top and bottom smooth. Kind of a trial and fit as you go. Sorry.
Old Dec 18, 2016 | 06:31 PM
pirate4x4_camo's Avatar
pirate4x4_camo
@lightflyer
The color of the wheel I posted in this thread is a blend I made up, call it "camo ranch"
Here are easy to work with out of the bottle colors.
Old Feb 26, 2017 | 09:32 PM
timf150's Avatar
timf150
Finally installed my Navigator steering wheel which gave me the steering controls for my Pioneer radio. I ended up using the SWI-CP5 from Pac Audio.
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
I also picked up a wiring harness but only ended up using one wire because I don't like cutting my OEM wiring harness'. Its the PAC 98-04 Adapter Cable 20-Pin for Ford.
https://www.amazon.com/gp/product/B0007TXP3I/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0007TXP3I/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I did have issues with the setup as the documentation is a bit lacking and my PAC device would not work with my Iphone or Ipad so I spent a bunch of time trying different wires and setup to get it configured. I tried to update the firmware and couldn't get that done either.
I ended up getting the auto-configuration to work with my PC and going through the setup had better instructions for connecting up the wires. I had already figured out how to manually set it up so I ended up setting up with the manual method.
So far I do like having the steering wheel controls for my radio and I especially like the fact I can setup the 4 buttons to do two tasks each so its like having 8 buttons.
Tim M
