Check and make sure. I know on the build they have two 20" that look the same except the center cap and hub. If you click the other it adds the above 10,000 package.
There are two sizes. The under 10,000 appears to have a smaller hub axle
I agree. When you build a truck switch from F250 to F350 (SRW) and watch the front wheel center where the locking hub sticks out. The F350 is clearly larger. I don't know if it just sticks out further or is actually bigger in diameter.
