Body swap
Old Nov 26, 2016 | 05:20 PM
Chris 307's Avatar
Chris 307
Body swap
So im swaping my 77 F250 camper special 2 wheel drive over to a 85 4X4 frame, the tanks on the 85 have electric fuel pumps on them but the engine is a carburated 460, can i bypass the fuel pumps and jut put a mechanical pump on the block? and is there anything else that i might run into that would cause me problems?
Old Nov 26, 2016 | 06:09 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
The frame is wider
Just get the earlier non electric pump sending units for the tanks and you will have no issues
Old Dec 2, 2016 | 02:07 AM
four-sixty-power's Avatar
four-sixty-power
Ive heard the cab mount points are in the same spots regardless of wider frame widths but I havent measured it for myself.
Old Dec 2, 2016 | 09:05 AM
Rollingscrapmetal
I can't imagine they would be
The radiator support is outside the frame on the later trucks so it's like 42-44 or so inches between them
I can't imagine they would have made the radiator supports on the 70s trucks stick out 6 or more inches on either side
I bet you could move all the supports to inside the frame
Old Dec 2, 2016 | 10:25 AM
4x4slik's Avatar
4x4slik
As long as the 460 has the spot for a mechanical fuel pump that is not a problem. I do not believe using earlier sending units is an option, as I believe the sending unit holes are larger on the electric fuel pump type tanks. Bypassing the fuel pumps would be the best bet. But this does raise another question. Will the sending units in the 85 send the right signal for the fuel gauge to work?
Also, the rad support on the 70's trucks bolts right next to the radiator, which leave 6 or more inches of rad support hanging out on each side. I would simple measure your mounting locations.
Old Dec 6, 2016 | 12:59 PM
Chris 307's Avatar
Chris 307
Would it be a good idea to swap tanks as well? that way i know the pickup lines would work just not sure if the tanks are the same size
Jwhit85
23
Oct 4, 2023 04:28 PM
390Posi
Apr 16, 2015 06:30 PM
Ziegelsteinfaust
Jun 25, 2013 07:59 PM
Rogue_Wulff
May 23, 2011 03:59 PM
kris bassett
Oct 2, 2006 08:10 PM
