T18 yoke compatibility
Old Nov 26, 2016 | 12:17 PM
idealtrucks's Avatar
idealtrucks
I just put a t18 out of probably an 80s model truck, and the yoke ended up being for a bigger ujoint. I think 3 5/8. I pulled off the yoke from my old transmission, and it wouldn't go all the way in the other transmission. The old yoke had splines all the way to end and other did not. Is there anything I can do to resolve this, like changing the end piece?
Old Nov 26, 2016 | 07:06 PM
orich's Avatar
orich
A better picture would of helped. Most the time the front yoke from the new mating drive line has to be welded onto the front of your old drive line. Ford used sometime a 1310 & 1330 u-joints to mate up larger yokes.
As can't make out the part you posted.
Orich
Old Nov 26, 2016 | 08:19 PM
idealtrucks
I can get a better pic, but not sure what your looking for. I need the smaller ujoint, but the yoke out of the earlier model transmission won't slide all the way into the later model transmission. It appears because the splines come to the end. The latter model yoke will go all the way into the earlier transmission though.
Old Nov 28, 2016 | 04:55 PM
JEFFFAFA's Avatar
JEFFFAFA
Ford used to make a hybrid u-joint. Part number was C5TZ4635F. It was a 1310/1330 hybrid. 3-1/4" across two ends and 3-5/8" across the other two. Aftermarket world prolly carries it to. Or:
C5TZ4635F:
Haven Ford
(620) 465-2252
xKlimesh Motor Sales
563-562-3241
xGreen Sales
(800) 543-4959
xRPN Parts
888-864-9305
xManderbach Ford
610-929-3683
AND
Premium Listings
NOS Parts Ltd.
Recently UpdatedPart Number:C5TZ4635FSeller:NOS Parts Ltd. -Description:UNIVERSAL JOINT KIT-DRIVESHAFT Phone 1-972) 937-2201
Quantity:13
Miller Obsolete Parts
Part Number:C5TZ-4635-FSeller:Miller Obsolete Parts - View ProfileDescription:U JOINT KIT Phone 1-607) 722-5371.
Quantity:4
Dennis Carpenter Ford Restoration Parts
Part Number:C5TZ-4635-FSeller Dennis Carpenter Ford Restoration Parts - Description:NOS** UNIVERSAL JOINT KIT Phone 1-800) 476-9653
Quantity:18
Obsolete Reliable Parts
Part Number:C5TZ-4635-FSeller:Obsolete Reliable Parts - Description:Phone 1-229) 686-5101
Quantity:2 Part Type:NOS
FLgargoyle
Sep 15, 2018 09:04 PM
FORD~
17
May 17, 2017 09:05 AM
Bad Bad Leroy Brown
Oct 22, 2012 07:28 PM
NAKPERFORMANCE
Mar 25, 2008 11:37 AM
f1drivr
1947 and Older Ford Trucks
Sep 21, 2004 01:20 PM
