460 swap???
460 swap???
I have an 77 with a 460 that is a beat up old farm truck but runs great. I also have an 86 with 460 that jumped timing and caused fire this summer and it has sentimental value it needs to be a daily driving. Can anyone tell me if the 77 beguine is interchangeable with the 86??? That would save me a lot of money in the swap...
Thanks
Thanks
1977 460 will be internally balanced. Mid-year 1979: FoMoCo changed the 460, it's externally balanced, has a weighted crank spacer. The block casting number is D9TE-6015-AB
All 1968/82 460's were only available with the C6. 1983 was the first year the 460 was available w/a M/T & 4WD
All 1983/97 F250/350 460's have a hydraulic clutch.
Sorry I'm not more knowledgeable with your original answer.
If your 86 is a manual transmission, you have some head scratching and figuring to do. Do they make a internally balance flywheel for a 460 manual transmission? Someone may reply that knows, just wait a little bit.
The only internal balance M/T flywheel will be found on 1969/71 429 Ford/Merc Passenger Cars.
otis348
13
02-11-2019 05:39 PM
Sschultz13
09-30-2016 11:15 AM
jamusfam
04-25-2014 10:38 PM
quehele
11-18-2005 10:49 AM
