Percentage of max tow
My current tow config is 7800# max tow based on model, engine and axle ratio.
My rig has the tow package, "E" rated LT tires and Firestone airbags.
2014 F-150 Super Cab, 4x4, 5.0, 3.55
I want to buy a travel trailer.
How far would YOU push it regarding the weight of a TT?
I have heard about 20% of rated capacity.
Is that reasonable?
20% of 7800# is 1560# leaving 6240# for max tow.
I feel close to 6000# would be doable.
What say the experts?
Is that reasonable?
You should be able to tow to max rating although at the top end of the tow rating you will probably run out of payload first. The issue will be will you be comfortable with it. I towed my 28BHBE (6700lb dry) with my 2015 3.5 EB without any problems. The issue I had was that I felt that the truck was to light in heavy cross winds with the huge sail in the back, but that is just me. It may not bother you at all so as I said it depends on what you are comfortable with. The truck will tow it.
Steve
I was pleasantly surprised with how well the EB F150 towed. It towed my trailer great and it is at the upper limit of what I would consider for a F150 but my preference is for a heavier truck if you tow longer distances. Short distances I think it would be ok in the wind. It is just my own preference. Some people I have seen is not bothered by the heavy cross winds, but I was and that is why I said it comes down to personal preference.
Received 6,693 Likes
on
Given that I was going to be pulling 11,000 lbs over 11,000' mountain passes I wanted to keep my trailer to 80% or less than the towing capacity of the truck. The 2016 Superduty pickups that I looked at on the lot would not fit that limitation. Most of them had a stated towing capacity of 11,500. With the higher capacity of the 2017 I'm going to be just fine.
Steve
I have never understood the 20 percent rule. These trucks cost a lot of money. You should be able to get your money's worth.
These trucks are test driven well over the gvw, and payload. Thousands of miles. Construction companies overload trucks everyday. The only issue I have is the safety aspect with braking and suspension. As long as the trailer brakes are properly maintained along with the trucks suspension and brakes, max it out if you need to.
But with that all said, if I were looking at maxing out the gvw and gcvw, I would add some help to the rear suspension, get the best wdh, and make sure I had good cooling for the transmission.
The majority of breakdowns I have seen are tires and transmissions. The majority of single vehicle crashes were vehicles with travel trailers and caused by trailer sway. Sometimes trailers were confirmed to be overloaded, but most were not checked if it no other party was involved.
Most crashes are determined to be driver error. Driving to fast for conditions, overloaded, and inattention. Or all the above.
I have heard both the 20% and also the 10% rule. And, I agree these trucks will handle their ratings. It would be interesting to know how weight and conditions actually affect longevity. It would seem, for example, an engine turning fewer RPM would last longer than one turning at the red line, if that difference was maintained for substantial periods of time. It also would be the case, we are normally advised not to "lug" the engine or just letting an engine idle for prolong periods, which would argue against simple conclusions about RPM.
There are so many variables here it is hard to make a "one size fits all statement".
Steve
Steve
Steve
Steve
I look at it this way. That same truck, with VERY minor tweaks is rated to tow more than 12,000 lbs. To me, the things that matter are brakes, TBC, and anti-sway. As far as I know, there are no differences in those between F150 models.
So I would say for your truck, I know I would be comfortable doing 100% and more of the rating. Especially if it's a short trailer, like for hauling gravel or something. The guys above are right that payload is likely to be your limiting factor.
The reverse of that is that I would be uncomfortable with a really long travel trailer behind the F150 no matter what the rating. I've seen people pulling 32' trailers, and that kind of length and side-area can cause big problems.
So in summary, it depends.
Not sure how one gets to 12K tow capacity from the published 7800# rating....even with those minor tweaks?
I'm not saying YOU can make any tweaks to change the factory tow rating. What I mean is that when ford makes those small tweaks at the factory, the published tow rating goes up.
I understand why it works that way, but to me, it seems silly to apply the same arbitrary percentage derating to a truck that's at 7800# as a nearly identical truck that's rated at 12,200#.
