torque specs...
Old Aug 25, 2003 | 12:23 AM
lovemusik's Avatar
lovemusik
torque specs...
anyone know the torque specs on the intake manifold and valve covers for a 390? also, how do i find out what running gears i have in my 67 f100 sb.? and, i'm changing from manual to power steer...will i need a different column????
thanx,
roger
Old Aug 25, 2003 | 11:55 AM
Freightrain's Avatar
Freightrain
torque specs...
Torque specs: Intake around 25-30 ft lbs I think will do it.
Valve covers probably around 10 ft lbs-not much or it will crush gasket.
Never really read the book to know exactly. Sure someone here will know the real numbers, but I think I am in the ballpark.
As for rear gear ratio. Look to see of there is still the factory tag on one of the bolts holding the center section in. The bottom line should tell you 3.25 or 3.00 or whatever it may be. If the tag is missing then you need to jack up truck and rotate driveshaft and see how many turns the wheels turn for driveshaft revolutions. It should get you close....3 1/4 revolutions(of driveshaft) to 1 tire=3.25 ( and so on)
As for steering column, not sure you need to change everything. It all depends on which box you will be using...I THINK. Again, someone here should be able to point you in the right direction.
Larry
Old Aug 25, 2003 | 12:09 PM
MuchToMyDelight's Avatar
MuchToMyDelight
torque specs...
I second the torqe specs.
Old Aug 25, 2003 | 12:44 PM
BB's Avatar
BB
torque specs...
Intake 32 - 35 ft. lbs.
Valve cover, sheesh I'll have to dig that up.
Barry
Old Aug 25, 2003 | 03:08 PM
BB's Avatar
BB
torque specs...
Found it, 10 - 12 ft. lbs.
Old Aug 26, 2003 | 05:32 PM
lovemusik's Avatar
lovemusik
torque specs...
thanx fellas, this will help a lot! i'm still painting up the motor and almost ready to put it ALL back together. i'll post some pics shortly so you guys can see... i'm sure i'll have more questions, so see ya soon
Old Aug 27, 2003 | 12:46 PM
buzzard's Avatar
buzzard
torque specs...
Has anyone really ever put a torque wrench on their valve cover bolts?
Old Aug 27, 2003 | 01:30 PM
BB's Avatar
BB
torque specs...
I did it once just for fun!
Barry
Old Aug 27, 2003 | 02:48 PM
Mil1ion's Avatar
Mil1ion
torque specs...
Here is a page you might want to bookmark.
http://members.tripod.com/torquespecs/generalp2.htm
