1979 Ranchero 302 AC Problem
Old Aug 24, 2003 | 11:13 PM
abesmith69's Avatar
abesmith69
Hello im trying to add freon to my Ranchero....I have found the port on my compressor to add freon, or what I believe is the correct place, I have bought a couple of adapters and I havnt had any luck with recharging the system....I dont know if it is the adapters or if im just doing something wrong.......
any help would be appreciated.
Thanks,
Abe
Old Aug 27, 2003 | 06:07 PM
abesmith69's Avatar
abesmith69
ttt
Old Aug 27, 2003 | 09:27 PM
94van's Avatar
94van
Make sure you have the right fill port. If you fill thru the high side, you can hurt yourself bad. The low side port will be in the line between the compressor and the drier, or sometimes even on the drier.
Put a set of gauges on the system first to see if you actually need freon. If it's low, or empty, you have a leak, which should be repaired first.
jllaco
18
May 30, 2013 11:57 AM
jllaco
May 24, 2013 11:27 PM
pitmanr2003
May 12, 2009 05:08 PM
Goose_52
Jan 24, 2007 06:36 PM
Ben_2
Jul 20, 2001 11:58 AM
