Sponsored by: Real Truck
Wow
Old Nov 21, 2016 | 04:07 AM
ExDakotaOwner's Avatar
ExDakotaOwner
Wow
First snowfall in the NE...and my f350 let me down. Cant even get it up hills. Sad day when my dakota out performed this truck. May just need new tires. 4x4 will need to get checked. Btw, was 60 degrees 48 hrs ago
Old Nov 21, 2016 | 04:27 AM
seville009's Avatar
seville009
Manually lock your front hubs.
If the 4wd is working, throw some weight in the back. I carry 5 80lb tubes of sand in my daily driver
Old Nov 21, 2016 | 07:09 AM
Slowpoke Slim's Avatar
Slowpoke Slim
If you're still running on the factory issued "Contracrap" tires, get rid of those. They're only good for tire fires.
Old Nov 21, 2016 | 09:23 AM
AZLugz's Avatar
AZLugz
They do really good burnouts
Old Nov 21, 2016 | 03:16 PM
ExDakotaOwner
This snow came out of nowhere.
How do I manually lock them? Still out on the street buried. Later on Imma have to dig it out and get it in the parking lot.
Old Nov 21, 2016 | 03:56 PM
redford's Avatar
redford
FTE Leadership Emeritus
Turn the front hubs to LOCK. Turn on 4WD when you need it.
Old Nov 21, 2016 | 07:16 PM
eberlestock's Avatar
eberlestock
Super dutys aren't really the best 4x4 out there, at least compared to compact 4x4 rigs. They work but their real intention isn't "a runabout truck".
Old Nov 21, 2016 | 07:58 PM
ssunit1's Avatar
ssunit1
First snowfall - - WTH?? Oh wait, forgot it is mid November. That white stuff is not really a concern to us in S Florida. No real hills either.
Y'all up north enjoy the winter season
Old Nov 21, 2016 | 08:12 PM
don123's Avatar
don123
I plow with my stock Michelins 275-70-18's. A dedicated snow tire would be the best solution. If you have the stock conti's forget driving in the snow.
Old Nov 22, 2016 | 12:20 AM
ExDakotaOwner
So it is still stuck. And guess whats under the snow that I was able to get to park? Yes...10,000 leaves. Making matters worse.
I have AAA. See if they tow it to get new tires. Ill never get home everynight at this rate. These are not big hills by any means.
Any suggestions on all terrain tires? Or tires that can get me home everyday it snows?
Old Nov 22, 2016 | 12:24 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
if your front axle is locked and the transfer case is working you should not have an issue, sounds like you have another problem causing you to only have 2wd.
Old Nov 22, 2016 | 04:25 AM
seville009's Avatar
seville009
Is your 4wd working and you're just stuck, or is your 4wd not engaging?
Old Nov 22, 2016 | 07:45 AM
BandBFord's Avatar
BandBFord
Just from experience, I have used BFGoodrich AT's and General Grabber AT's.
My preference is the BFGoodrich AT KO2 tires, they perform very well in the snow and are significantly quieter than the previous version.
Old Nov 22, 2016 | 08:02 AM
Irelands child's Avatar
Irelands child
The Continentals on my last F350 wouldn't even 'pull' my 3-4% driveway without a running start. Switched to a set of Kumho's and that problem went away. Leap forward, the current F250 had Firestone's. Not great but the new Michelin's didn't even need 4wd.
What you didn't say is that this snow storm drop is sloppy and about the consistency of wet concrete. It packs and gets icy. If your truck is buried in a foot plus of that slop, it just wont go. Oh and the Capital District/Saratoga part of NY State - only about an inch of sloppy stuff, most of which is long gone today
Old Nov 22, 2016 | 08:13 AM
AZLugz's Avatar
AZLugz
I heartily disagree. I have had three SD diesel 4x4s and, tho I do not deal with snow here, they have been used in off road recovery, towing trailer into areas for picking up off road buggies and doing some general wheeling....Amazed the ****e out of people when I made it thru box canyon in the 09 CCLB. I drug an abandoned 70s bronco about 6 miles on its roof from a wheeling area up some pretty knarly climbs and thru all this I continued in areas where the chubbies failed to climb and one of the runs I had to tow the dodge up and out of the wash..... No, they are not made to do what the little 4x4s are, but these things are beasts in their own right
