1993 ford explorer limited
Old Aug 24, 2003 | 10:27 PM
lwagg2's Avatar
lwagg2
Question 1993 ford explorer limited
i recently bought a 1993 explorer limited it only had 1 rke so i purchased a couple more and been trying to find the programming pins so i can jump them in the left qaurter panel but every wire and every plug are in use is it possible that the limited used a different programming way i have tried just the ignition 3 5 and 8 times to see if that would se tit off but no luck there either anyone have any suggestion ?
thanks
Old Aug 26, 2003 | 06:33 AM
satcomjimmy's Avatar
satcomjimmy
The Keyfob that came with the truck, is it the normal Factory fob with Arm, Disarm, and Panic buttons? My problem was that the 95 I bought had a dealer installed alarm in place of the factory on, fobs only had 2 buttons (and power memory seat doesn't work with them)
Old Aug 26, 2003 | 03:14 PM
lwagg2's Avatar
lwagg2
After a Trip to the local ford dealer I now know where this pins are located if anyone else would like the details feel free to email me and i will respond with detailed instructions and a digital pic of the wiring that you need to jump on these year fords
lwagg2(No Email Addresses In Posts!)
