Diesel Chevron, Shell, other?
Old Nov 19, 2016 | 04:22 AM
coolidge54's Avatar
coolidge54
Well I'm going to have to fill up this 48 gallon beast of a diesel tank this weekend. The two major brands I have in my area are Chevron and Shell. I could drive farther and maybe find a Mobile station. For diesel does it really matter vs gas?
Being my first Diesel truck one thing that concerns me are stories about Ford denying warranties due to people buying bad diesel.
Old Nov 19, 2016 | 06:08 AM
43davel's Avatar
43davel
The advantage of diesel over the ethanol gas garbage that is used offered today is the shelf life of diesel is years instead of months.
Old Nov 19, 2016 | 06:10 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Just find astation that does alot of volume, brand makes no difference
Old Nov 19, 2016 | 06:12 AM
fidel.medrano's Avatar
fidel.medrano
I agree with Kubota,
just pick a station that does a lot of volume. I keep my receipts as well just in case.
Old Nov 19, 2016 | 06:30 AM
HouseMouse's Avatar
HouseMouse
Volume, Volume, Volume. Stay away from the Mom&Pop's.
Old Nov 19, 2016 | 07:42 AM
johndeerefarmer's Avatar
johndeerefarmer
Yes but storing diesel long term means a better chance of having water and/or algae in it.
You also want the highest cetane level possible. It's not on the pump so you will have to contact each manufacturer and see what they are providing.
Where I live in north Texas our cetane level is 48 minimum, most of the rest of the USA is a minimum of 40.
Old Nov 19, 2016 | 07:44 AM
EpicCowlick's Avatar
EpicCowlick
I agree with the idea to fill up only at volume/big brand stations. If the station is quaint, I aint. The big risk is water in the fuel. And yes, keep the receipts and check your water filter once in a while.
Old Nov 19, 2016 | 07:51 AM
Windy City's Avatar
Windy City
This thread (and the first cold weather here) triggered me to do a search on diesel additives. Knowing there is the Cetane issue, potential problems with wax and lubricity, and the possibility of gelling, but I don't have any experience with diesel.
WOW, what a bunch of marketing Kool-Aid out there on the subject! Tons of "good info" driven by sales not fact.
Anyone here in the northern climates have any experience and good results with any certain product or practice?
My truck is "scheduled" to arrive Dec 28, right in the thick of of the cold temps.
Old Nov 19, 2016 | 11:55 AM
johndeerefarmer
Since my cetane level in Texas is already higher than most I don't notice an increase in fuel economy when using additives like some do. I have used Stanadyne, Archoil and Optilube summer. Archoil has one advantage in that it takes very little to do the job. If I travel and carry other products I have to carry a gallon with me. I have also used Archoil in my chainsaws, generators and weed eaters and it will clean gunk out of them and have them running smoothly again without me having to tear them down and clean out the jets.
John Deere's additives are made by Stanadyne so I suspect that its a good product as well. If you are worried about your warranty then Ford's PM-22a would be a good bet. Which last time I checked was made by Gold Eagle which sells Sta-Bil and Diesel Power
Old Nov 19, 2016 | 12:49 PM
redz284u's Avatar
redz284u
which ever u pump from the 2 you should be good. One thing to keep in mind is, when on the road, don't pump at truck stop diesel stations. Stick to the gas stations
Old Nov 19, 2016 | 12:55 PM
hsb1993's Avatar
hsb1993
Why is this? I would think busy truck stops would have the freshest fuel available.
Old Nov 19, 2016 | 12:58 PM
redz284u's Avatar
redz284u
maybe fresh, but typically bad quality. Also I know flyinJ doent carry regular diesel, they use the bio diesel. Other use additives that are ok for big rigs, but not good for our trucks.
Old Nov 19, 2016 | 01:05 PM
hsb1993's Avatar
hsb1993
Thanks. Can you quantify this statement with specifics and empirical evidence supporting this statement? Not trying to be a smart***, being that this will be my first diesel (other than my tractor), I need more data than "I read it on a post" at FTE.
Also, does that include the diesel pumps that are on the passenger side pumps of the tuck stops?
Old Nov 19, 2016 | 01:07 PM
TrikeDawg's Avatar
TrikeDawg
I believe everything they sell in Texas now is bio diesel anywhere from 5% to 20%. That is why I use the 5w-40w T6 Rotella oil because of the bio.
Old Nov 19, 2016 | 01:13 PM
redz284u's Avatar
redz284u
flyingJ diesel: personal experience, u can verify this when u stop by to pump. When I did pump at one that didn't advertise the bio fuel, my truck went into regen mode every 50-75 miles. Pain in the butt.
Other truck stop diesel: there are plenty write ups with this info. Keep looking and the "empirical evidence" will be there
