Looks really good, nice work. I saved your picture for future use. I have always considered getting the factory fender moldings and having the paint done. I assume that's magnectic.
Unless something has changed you can put 35 12.5 18 or 20 under these trucks without any type of suspension modifications and no rubbing. It's all a personal choice and look. If you do use stock wheels a 12.5 inch wide tire will lower the towing and hauling capacity of the truck.
It has the blocks instead of replacement springs. I'd looked at the 35/12.50s but noticed a max psi of 65. Figured a lower tow rating. I would NOT recommend the Cooper STT pros though. I usually run the ST maxx and they are awesome, but they don't make them in a 295/65/20 so I went stt pro. They are LOUD. Half of the beauty of these new fords is how quiet they are. That's gone now. I had them siped or I'd bring them back. Epic, I'll try to get a cab clearance measurement when I get home
