Custom Tuning
Old Nov 17, 2016 | 03:43 AM
3722's Avatar
3722
Custom Tuning
Thanks in advance.
I had custom tunes written when my motor work was completed 8 months ago. The tunes were based on the stock transmission. I just got a new stage 2 Trans put in yesterday. My question is do the tunes need to be updated for the new application? Thanks
Old Nov 17, 2016 | 08:23 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Who did the tunes? You could always call them and ask, the good writers are normally willing to talk with you about things like major performance changes.
Old Nov 17, 2016 | 09:37 AM
3722's Avatar
3722
Got them from Warren <<nvr liked that one. Gear Head and WPE. The reason I'm asking is that the truck just doesn't seem near as fast. Almost feels like the gearing is different. Which of course I know it isn't. Sounds weird I'm sure but something definitely feels different. I've ran them all since the install and the feeling is pretty consistent throughout.
Old Nov 18, 2016 | 06:35 AM
WatsonR's Avatar
WatsonR
Load the stock tune and disconnect the batteries. Turn on headlights for a few minutes after, then reconnect. Drive truck a few miles and then load the tune. That will kill KAM, keep alive memory, has the adaptive learned driving habits stored there.
Not positive but I'd do a trans relearn as well. That should start everything from scratch.
Old Nov 18, 2016 | 10:37 AM
3722's Avatar
3722
Will do. So turn the headlight switch on while batteries are disconnected?
Not sure what a Trans relearn is but will look it up.
Old Nov 18, 2016 | 10:54 AM
WatsonR's Avatar
WatsonR
What your trying to do is discharge the capacitors that hold any type of memory. IF you disconnect the negative cables from both batteries, then just turn the headlights on, some say for 30 minutes... not sure it takes 30 minutes.
Yes, transmission relearn.
Hossfly05
Jun 8, 2015 12:25 AM
640 CI Aluminum FORD
2009 - 2014 F150
May 27, 2015 09:30 AM
SultanGris
6.7L Power Stroke Diesel
26
May 23, 2015 01:34 AM
mustang9701
Apr 4, 2015 10:00 PM
darren32
23
Mar 28, 2012 09:14 PM
