Interpret power balance test pics
Old Nov 14, 2016 | 09:41 PM
valutechpc's Avatar
valutechpc
Can anyone interpret which injectors are no good according to the pics? They have all been replaced. some from ebay (never again) and some from advance auto parts. Number 5 and 8 are motorcraft injectors. Number 5 looks a little weak to me. Should I send it back as defective? Number 7 looks higher than the rest. I have done a releative compression test and cyl 3 was 1% and cyl 4 was 2%. the rest are 0%. 2003 6.0 excursion by the way. first pic is cold and the second is warm.
Old Nov 14, 2016 | 11:37 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
If I were you, I would post this in the 6.0 forums. You will get a quick response there.
Old Nov 15, 2016 | 12:45 AM
valutechpc's Avatar
valutechpc
Ok. Thanks for the suggestion. Mods, please delete this thread.
Old Nov 15, 2016 | 08:42 AM
william_04_x's Avatar
william_04_x
Did you perform this test because of a running issue, or just because you were curious as to their performance?
Your graphs don't look too bad at all. Is "smoothing" On or Off?
Old Dec 16, 2016 | 05:33 PM
valutechpc's Avatar
valutechpc
Just a follow up, I replaced injectors 2 and 4 because the graph was showing the grey line to be very wide. Bucking is gone now. I'm still going to replace 5 too because I got a contribution code for that again. I already replaced it 2 months ago with a motorcraft injector. Guess I got a bad one.
valutechpc
Nov 16, 2016 02:40 AM
msgtg
West Virginia Chapter
15
Mar 20, 2013 07:51 PM
2006powerstroke90
Mar 19, 2012 07:41 PM
vlietracer64
Jan 26, 2011 05:13 PM
