100w headlights & wiring write up?
Would anyone want me to do a complete write up of prices and parts for installing new headlights and new 100w xenon bulbs.
the difference in brightness was incredible and looks stock with a extremely slight blue look on the lights of the truck. (mainly just bright white)
went on a 1995 f150 5.0 xlt, supercrew
I wouldn't be against the idea of higher wattage bulbs, if heat wasn't a concern for the plastic assembly and the connector.
Aftermarket or retrofitted HID is illegal. The optics are designed for a halogen bulb, so excessive glare is created.
I think I'll just stick with head light relays and good quality clear halogen bulbs that don't have any blue coatings on them.
20ft Of 12 gauge wire.
Electrical connectors (butt connectors with heatshrink was my choice)
Fused wire holder (for battery protection for hot wires, I choose 40 amp pin)
Eyelet connectors (for negatives and one for positive on batt.)
2 ANZO headlight relays (local o'reilly's has them, high and low 4 pins)
With the relays any should work but they need to be a OK for continually running
20ft of electrical conduit. ( I wrapped everything I could )
9007 100w bulbs
New headlight assemblies
9007 heavy duty ceramic headlight wire harness
Heavy duty zip ties to wrap everything nicely.
I went with some 100w xenon bulbs that are tinted blue on the outside but they do not appear blue like you think they would. they are more of a bright white. I will post pictures of the setup later this evening after I get done with some other stuff.
these headlights came in 2-3 days and fit like a glove. they seem to be well made but I still put a bead of silicone around the whole exteriors of them for leak-proofing.
these are the most important to using 100w bulbs. If you dont have something like this the risk you run in burning a connector is extremely high.
Even thought they are tinted blue, they do not come off the headlights blue, it is more white than blue
9007 100w bulbs
So it looks from the pics like those headlights come with bulbs; what were those like?
Actual link to the headlights - https://www.amazon.com/dp/B00KRSLPGI
Tibbetsni
25
05-27-2018 09:51 AM
