SEIC High Idle Upfitter Switch
Old Dec 31, 2017 | 03:14 PM
  #121
J Standard's Avatar
J Standard
It sucks that Ford doesn't offer this as a option, GM HD trucks can be ordered with this and it is nice as it makes the a/c blow cold on hot days.
Old Jan 9, 2018 | 10:33 PM
  #122
jsavelli's Avatar
jsavelli
Originally Posted by SGMJohn
Repo, I can't answer your main question definitively as I only have 500 miles and don't want to idle that long yet. But when my truck arrived at my dealer I requested they enable the high idle before I took possession. They did, assigning it to up fitter switch #1. I don't have a potentiometer so I can't adjust the RPMs but mine runs in the neighborhood of 1500 RPMs. I would say I believe the high idle overrides the auto shutdown. Otherwise I don't see what would be the use of the high idle. My dealer did not charge anything for enabling this. They didn't mention a price and I didn't asked! Thought I'd mention that incase you want to ask your dealer when yours arrives.
my dealer is clueless when I asked for it done. Who is your dealer? Thx
Old Jan 10, 2018 | 08:39 AM
  #123
17 Oaks's Avatar
17 Oaks
LOL, yes you have to wonder. If Ford simply included it in the electronics then it would be a simple matter of just turning it on and you can put it down into the code deep enough that the average Joe cannot get to it
Based upon the number of Diesel trucks they sell (and now the F 150) and the simple statement:
High idle is intended for use in all climates where idling longer than '15' min may cause possible long term damage to your vehicle and void you warranty.
Option U2 007...$85 MSRP
Ford can make a LOT of money on this and so can the dealer.
Old Mar 15, 2018 | 12:54 PM
  #124
hipwit's Avatar
hipwit
Originally Posted by AK_SuperDuty
I'll be installing this when I'm home next week. I plan to use a 22k resistor on the ground for the park switch input. I'll let you know how it goes.
I did the high idle mod (without parking brake bypass) successfully on my 2018 F350. Now I'd like to wire in the relay to ground the parking brake signal so I don't actually have to depress the parking brake. I'm worried about faulting the BCM since the Q-256 bulletin says the circuit cannot source any current. Did you have luck doing this with a resistor? The bulletin mentions using a 20 kohm resistor with a field effect transistor but I'm not exactly sure what this means (electrical engineering isn't my strong suit).
Thanks!
Old Mar 15, 2018 | 02:17 PM
  #125
ltr's Avatar
ltr
I really wanted to do this but got lazy and just bought the BD Diesel switch. Took 10 minutes.
Old Mar 15, 2018 | 06:19 PM
  #126
CO Wapiti's Avatar
CO Wapiti
Me too! It works great and you have variable idle up to 3000 rpm
Old Jun 18, 2018 | 05:01 PM
  #127
mrmag00's Avatar
mrmag00
Is the BD SEIU plug and play or do you have to tap power from the upfitter switches. Most of the you tube mods show tapping power from the upfitters.
Old Jun 18, 2018 | 05:37 PM
  #128
CO Wapiti's Avatar
CO Wapiti
It is plug and play! You just have to find a location to mount the rheostat and it plugs into a factory connector behing the passenger side kick panel where a fuse bos is located. I mounted my rheostat in the lower right hand corner of the knee kick plate where there was enough room behnind it to accept the wiring.
To activate it you just have to have it in park with the parking brake on and dial up the rheostat to the rpm that you want. I use it when I use my ARB twin compressors and I'll use it during any winching operation but I just havn't gotten stuck in this truck yet.
Old Jun 18, 2018 | 08:49 PM
  #129
17 Oaks's Avatar
17 Oaks
I turn mine off/on thru the Outfitter switches...
Old Jun 18, 2018 | 09:37 PM
  #130
Section179's Avatar
Section179
The issue of the Q-256 bulletin saying the circuit cannot source any current, and requiring a 20 kohm resistor with a field effect transistor has still not been addressed. Anyone do this with the resistor in place (FOR THE PARKING BRAKE MOD) and have it work?
Old Jul 29, 2018 | 02:04 PM
  #131
SARGODERIC's Avatar
SARGODERIC
4th Gear
Jerry, I know we are a year into thes last few threads but any pics and feedback in the relay being tied into the brake wire?
E
Old Feb 16, 2019 | 07:50 PM
  #132
Faceplant409's Avatar
Faceplant409
Finally got around to installing BD Diesel high idle kit.
Fairly straightforward. Would have been a piece of cake, had Ford sprung for 6”-8” more wire on the blunt cut pass-throughs..... ��
Used UpFitter #4 for trigger.
Put dial on an alum bracket I made inside upper glove box.
Old Feb 16, 2019 | 08:24 PM
  #133
mattymax's Avatar
mattymax
I don’t think you needed to use an upfitter for the BD kit. Plug it in. And whenever you wanna use it, set e brake.
Old Feb 16, 2019 | 09:00 PM
  #134
ltr's Avatar
ltr
How did you hook into the up-fitter switch? There's nothing in the instructions for this. The rotary switch clicks on and off.
Old Feb 16, 2019 | 10:23 PM
  #135
Faceplant409
Run a wire from upfitter blunt cuts to pass through blunt cuts and hook it up to yellow on the BD harness.
I did not use wh/Bl.
Dialed rotary where I wanted it and just use switch.
