Dual Tank Switch
Old Dec 29, 2001 | 08:50 PM
safedog 1's Avatar
safedog 1
Dual Tank Switch
I need to remove the dual tank switch to check for possible corrosion and wear. Has anyone removed this and what's the easiest way to do it? Any help is appreciated.
Old Dec 30, 2001 | 11:15 PM
madman666's Avatar
madman666
Dual Tank Switch
Old Jan 1, 2002 | 10:36 AM
mule1991's Avatar
mule1991
Dual Tank Switch
I removed this switch on a 89 f250.
You have to remove all the screws that hold the plastic cosmetic pieces on the column. Also, everything should just snap out.
Do not force anything. The column cover is a two piece cover on 89. Remove that. Then proceed to the screws and pry/snap the cosmetic pieces. My xlt has the rosewood color plastic around the gauges, i do not know what yours has. There is also a connector to the dual tank switch and two screws to it as well that hold it to the plastic snap in piece.
Jim
Old Jan 1, 2002 | 12:10 PM
safedog 1's Avatar
safedog 1
Dual Tank Switch
Thank's Jim! You probably saved me some broken pieces. Have a great new year.
