Pulling A 5th Wheel (input please)
#1 Ford says the rating for my truck is 10600#
#2 The trailor that I think I want will be around 12000#
#3 I won't be in the steep Rockie Mts.
#4 Question???? How much difference is there between the the two weights besides the math. Can I pull a trailor without a "lot" of concern ?
I know I can adjust for some of the weight by not pulling with lots of water and other things but assume that we're looking at 12000#
I also know that many people tow "overrated" (this does not make it right or safe) but I'm talking 1400 #'s and would like to here form you guys who have had, or not had extra repairs due to being just over the line in pulling weight.
Thanks
I am over weight, but I wouldn't advise it. hasnt hurt my truck yet but it does kind of worry me. I try to haul an extra four wheeler in the back of the trailer to take some weight off of the tounge.
We bought a 2003 F-250 SD; Crew Cab; 4x4; SRW; 6L TD; with the 3:73 rear. Look at the "*" at the bottom of the chart.
What # do you come up with for this truck towing a 5ver ?
Also what does my truck weigh (in the Ford chart), I can't find it.
Thanks
http://www.clubfte.com/users/monsta/TrailertowingV2.htm
I did all my research last year with the 2002 trailer towing guide, but didn't buy my truck til 2003. six weeks ago. I bought an F250 CC SRW FX4 6.0 diesel 5SP AUTO LARIAT trim package.
Here's how the weight ratings go as I am learning it.
The GVWR of our truck is 8800#. That means that the most weight allowable on the wheels of the truck is 8800#.
There are also front and rear axle ratings that are not to be exceeded as well, but their sum does not equal what you can put in the truck; they stipulate the front or rear maximums individually.
The trailer towing guide says our trucks can tow a fifth wheel up to 10400#; but that is based on the truck itself with a driver, mandatory options and no cargo. The F350 can tow 12700#.
Key phrase is "UP TO". They are the MAXIMUM you could tow if the truck had no options, cargo or passengers. All these extra things reduce pound for pound what you can really tow (legally).
In reality, you have to weigh your truck (look for truck stops with CAT scales; it'll cost you $8.00). If you weigh it with yourself and spouse in the vehicle, near full fuel tank, and the minimal cargo you will be carrying in your truck while you are towing your fifth wheel. You must subtract that weight from your GVWR of 8800# to determine how much is left over for the hitch itself and the king pin weight.
The firat time I weighed mine it was 8040#. Wooo!!! Doesnt leave much for the hitch and 5er. That was with my wife, myself, a truxedo plus tonneau cover with tool box, a few tools, a full tank of fuel, a cooler and luggage for a weekend at our campsite.
When we got home I took everything out and weighed it again with just myself and 3/8 tank of fuel. It weighed 7320#. That leaves almost 1500# for hitch and pin weight but no wife (hey??) no cargo, or food and drink, and very little fuel.
The pin weight of a 5er is generally between 15-25% of it's total weight. Mind you the weights listed in the brochures are lower than they really are, and get worse when you load up your gear.
So, the bottom line is the F250 with it's 8800# GVWR really limits the 5er you can tow. The F350 with it's 9900# GVWR gives you and extra 1100# of hitch weight head room.
Had the trailer towing guides from Ford been more informative than misleading, I and probably you would have bought the F350 instead.
Hope that'll help.
Thanks for the insight. It is a little dishearting the way Ford explains the stats. in their lit. but unfortunately I have a hard time beleiving (that only a few hundred lbs. here and there are going to make a significant difference) in towing a 5er. I'm not going to go over more than 2-300 lbs. even on your #'s. and I factor in how safe of a driver I am.
The 20,000 lbs. "Total" does'nt that mean that I can't tow a total combined weight of 20,000 between the two.
My truck is just like yours
2003/ F-250/ SD/ CC/ 6L /FX-4/ Tshift Trans/ 3:73 rear /camper pkg.
Any imput from others who know their 2-400 lbs. over???????
The 250 and 350 are the same truck. The ONLY difference is the 250 has a 2 inch block in the rear and the 350 has a 4 inch. That is why the 350 sits higher (it can take more weight before "sagging"). The suspension, tranny, frame, engines, wheels etc. are the same.
Add air bags to your 250 and you will have a 350 (without the door stickers and badges).
I researched the heck out of it before I bought mine. Let me say this before I get flamed....the above is true on 2003 for sure and I think 2002.
I can understand the 350 having a 4" block and the 250 having a 2" block, but what I don't understand is why does the F-250 CC 4x4 have a heigth of 79.8 inches and the same in a F- 350 has a height of 77.1 inches
