2016 6.2- Factory oil fill
Thanks for the heads up. I typically park the truck at about a 3 degree incline leaning about a degree to the passenger side- just the way the terrain is- So I don't normally check the oil (bad excuse I know) knowing I won't get an accurate reading. the truck was flat the other day so I checked it and I'm in the middle...but I feel better with it being at the top! do you know if it is a 1 quart dipstick...from the bottom to the top...
It doesn't matter, you can pretty much mix weights and base stock all you want inside the appropriate APIC rating, especially if it's just a half quart to top up. Grab a one quart bottle of whatever oil you're going to start using going forward, and add what it takes to get the level where you want it.
That being said, just because the oils mix doesn't make it right to switch viscosities. Wal Mart sells quarts of Motorcraft 5W30 here, so that would be my default option. I wouldn't change the 5W30 rating because there's no need to IMO, so if you were to get a bottle of something else that you'd rather use like Mobil 1 5W30, it won't hurt anything.
BII Plow Truck
2017+ Super Duty
96
03-25-2017 09:27 AM
