I think that you have other bolts in that transmission mounting system that are the same size diameter as the ones that you are trying to match. Pull one of them and see if they thread into the holes that you need them to fit into. Then check the length to be sure that it is right. Check it out !! Now you know what you need.
Sorry that I don't have mine here to check. I am not sure that I have the same transmission that you do anyhow. None of us know what transmission you have because you did not state that in your post.
Ok , the type tranny does not matter GENIOUS!!.. what i am asking is the block tapped metric or standard. So there is no need for you to type in bold.......
None the less...I think that you have other bolts in that transmission mounting system that are the same size diameter as the ones that you are trying to match. Pull one of them and see if they thread into the holes that you need them to fit into. Then check the length to be sure that it is right. While you are at it look at the head and see if it is marked as a metric bolt. Check it out !! Now you know what you need.
Your right...I don't need to type it in bold. That was my choice..Something we have here in the U.S.A. But none the less...can't you find this answer yourself, Genius (please note the correct spelling).
Please, I am only here to help and I never said that I know it all because I don't. But I will tell you that it would take 2 minutes of your time (about the same amount of time it took you to type this retort) to find this answer yourself.
P.S.
Sorry if I have insulted your intelligence...that's not what I was aiming for. I was aiming for your inability to remove yourself from in front of your computer and get your hands dirty. Perhaps there will be another post here tonight that will give you a direct and concise answer to your question. Even at this point...If I had the answer I would tell you because I am a member here to help others with their problems.
