Bestop Power Step Install
Old Nov 5, 2016 | 07:39 PM
Zazoos's Avatar
Zazoos
Thought I would share my power step install on my 1971 F250.
These are off a GMC truck, not sure of the year.
Front Bracket made from square tubing that I cut the the bottom out of. Just tried to use stuff I had on hand.
Rear Bracket is built in place and really is just a hanger with a brace to the frame.
The sheet metal screws were just temporary. I came back and welded the angle iron to the bed cross members.
The used steps did not come with the controller, so I went with KP Technologies.
I just stuffed the relays and controller inside the body between the door hinges.
Had to add a door pin switch as the OEM stuff would not work correctly with the KP Controller since the OEM are powered rather than just ground. I did wire the power step lights to the OEM door pin switch.
Old Nov 5, 2016 | 07:59 PM
ultraranger's Avatar
ultraranger
That's slick as socks on a rooster right there. Nice truck too.
Old Nov 5, 2016 | 09:50 PM
Randle's Avatar
Randle
2x Steve, that is really nice and on a sharp truck.
Old Nov 5, 2016 | 09:53 PM
GaryKip's Avatar
GaryKip
Very nice! Any more info on what truck they came from? Were they a factory option, or maybe an aftermarket thing? Any model name or numbers? That setup looks perfect on your truck. Good work with great results, thanks for sharing!!
Old Nov 5, 2016 | 10:19 PM
Zazoos's Avatar
Zazoos
Not 100%, but I'm fairly certain from an 08 GMC 1500 4 door truck. From looking at the online instructions at Bestop it looks the same as all the year models for the GMC and Chevy. Yes, I believe it was an aftermarket addon.
http://assets.bestop.com/files/_best...8/75126_is.pdf
Old Nov 6, 2016 | 07:11 AM
D & D's Avatar
D & D
Nice work for a very nice looking truck.
Old Nov 6, 2016 | 07:23 AM
HIO Silver's Avatar
HIO Silver
Nice job.
A couple of questions:
What is the overall length of the steps?
I can think of a couple of situations where I wouldn't want the steps to extend,. Does the controller provide for an override switch to disable the steps?
Old Nov 6, 2016 | 03:42 PM
Zazoos's Avatar
Zazoos
The length is 80 inches. The end caps can be removed and the steps cut down and the caps re installed.
The controller does not have a disable function, I used my power window circuit which did not get used in the build and you can just pull the fuse to disable.
Here are couple more pics.
Old Nov 7, 2016 | 04:59 AM
GaryKip's Avatar
GaryKip
Looks good and the setup and install didn't seam too difficult.
Old Nov 8, 2016 | 04:52 PM
JEFFFAFA's Avatar
JEFFFAFA
Nice ideas. NICE TRUCK. If my C/S was a highboy I'd be all over this.
Old Dec 30, 2016 | 07:31 PM
ricteroff's Avatar
ricteroff
thanks for info
Zazoos
Nov 6, 2016 03:43 PM
Austinhartman
Jul 2, 2016 08:43 AM
Mtphammer
Oct 4, 2015 11:35 AM
Tom French
20
Apr 14, 2013 10:24 PM
BradyCouchman
S. California Chapter
16
Nov 12, 2008 08:46 AM
