A Goober and a Welder= My Truck
Old 06-07-2017, 08:20 AM
humphrey169's Avatar
humphrey169
humphrey169 is offline
I got my new hood put on Saturday morning. Cervanti 2 inch
  #107
Old 06-07-2017, 10:23 AM
offwhitefueler's Avatar
offwhitefueler
offwhitefueler is offline
Dun dun dunnnnnnn.....
Looks rad!
How's it running?
  #108
Old 06-07-2017, 10:32 AM
humphrey169
It's hitting softer. Seems like the timing slipped again. When I get a chance I'll check it . The 410s may be part of the problem too because the harder you push it the more boost it makes so the better it runs. With 355s it loaded it harder....if that makes sense.
  #109
Old 06-07-2017, 10:34 AM
humphrey169
That's a back road run at about 10lbs of boost. Just doesn't hit like it did
  #110
Old 06-07-2017, 10:36 AM
humphrey169
10lbs at launch and around 65psi at full tilt
  #111
Old 06-07-2017, 10:37 AM
offwhitefueler
It seems like it should make sense. Keep posting! Love seeing all the stuff you push through and get done. : )
  #112
Old 06-07-2017, 06:26 PM
humphrey169
I'm gonna use a powerstroke radiator in place of the idi setup. It's supposed to a couple inches narrower than an idi. I need more clearance between the intercooler tubes.still need to find the rubber pads that the radiator sets on. I also have to cut the inlet and outlet off and switch sides so I can keep my current hose setup
  #113
Old 06-08-2017, 04:23 PM
humphrey169
I got some new goodies
  #114
Old 06-09-2017, 04:00 PM
offwhitefueler
jeaaaalllllousssssss
  #115
Old 06-10-2017, 01:52 PM
Laggy's Avatar
Laggy
Laggy is offline
My wrangler is on it's 2nd Mishimoto radiator (replacement), and i'm about to swap for a 3rd. I wanna love Mishimoto, but.....
I do have a Flowkooler water pump, but the water pump is on the pull....That is the only other possible explanation
  #116
Old 06-10-2017, 03:08 PM
humphrey169
What's been the problem with the first two radiators
  #117
Old 06-11-2017, 03:31 AM
Laggy's Avatar
Laggy
Laggy is offline
Leaking. Different spots.
I have a friend that got a $100 garbage aluminum radiator off eBay and he's run 20k on it, zero issues. What are the chances?
  #118
Old 06-12-2017, 01:22 AM
humphrey169
If it's leaks at the welds then I can fix those, but if it's the core then I'll have to see about sending it back. But I'm going to be cutting it and modifying it some so I don't know how every having to return it would work. We'll see
  #119
Old 07-17-2017, 07:37 PM
humphrey169
Here's a shot of the shift.
  #120
Old 07-17-2017, 07:51 PM
humphrey169
Here's a video.
Quick Reply: A Goober and a Welder= My Truck
