Family 56 rebuild thread.
#31
#32
We'll you never know what life brings. My progress has been all but halted due to my wife's Colorectal Cancer treatments. So I farmed out the installation of driver side firewall, both front floor panels, inner and outer rear cab corners, front cab corners, & both rockers. They are also going to "fix" the roof. Right after I got the cab to the body shop I ended up with a bout of Accute Pancreas. Three days in the hospital and I'm out but homey doesn't get to eat or drink anything fun
Master installed third time's a charm.
Residual check valves installed too.
#33
Forgot. The body shop thinks they can find a different 56 roof. So far they've sent me to look at 2. Both were as bad or worse than mine. They may have found another but haven't called me to go look at it yet. The roof repair is going to be an expensive endeavor but I really don't want to install a fiberglass one.
#39
Look'n good BJ. That stinks that your foam is the wrong size. As I have read in other threads, quality control does not seem to be a top priority for a lot of companies. Even though they may work with you getting it corrected, it's a pain in the butt Time is valuable. I notice that even more as I get older.
What are you using for a seat cover? Looks like the original under the foam. Good luck and keep plugging away.
#40
#41
I bought a used seat cover on eBay.
Seat back with cover on.
Closer view of the seat cover.
The stuff on the seat is burlap.
Burlap on top of seat bottom.
Kevin, I spent 30 plus years inspecting maintenance shops for the military and Federal Service. It always amazed me when I saw a super clean and organized shop. I can rarely walk from one side to the other without tripping over something.
#42
#44
I found a roof! The body shop nor I were happy with how the "fixing" the roof was going. Soo $200 and 4 hours round trip and I now have a solid 56 roof. Only issue is it was from a farm truck (presumably a grain truck) and it has holes for running lights. I was so excited I drove it straight to the body shop without taking pictures. I'll go by Monday and snap a couple.
#45
