2017-2019 Super Duty FORScan Spreadsheet
#2986
it isn't (on the cluster/display) - but you CAN see it if you use forscan lite (on a phone) or read the PID's using the laptop
#2988
Maybe this question has been asked, but what is the approximate range of the bluetooth receiver? My laptops are all Chromebooks, however, my desktop is running Windows 10 and is just on the other side of the garage wall. With the truck in the garage, I'd guess distance between the desktop and OBD port would be about 15'.
Thanks!
Thanks!
#2989
Thanks!
Thanks!
#2991
Received 6,697 Likes
on
Thanks!
Thanks!
#2992
Thanks!
Thanks!
Technically, Bluetooth is classified by standard (e.g., Class 1, Class 2, Class3, etc.), and each standard has a minimum range.
From the Wiki entry @ https://en.wikipedia.org/wiki/Bluetooth
Range is power-class-dependent, but effective ranges vary in practice. See the table on the right.
Officially Class 3 radios have a range of up to 1 metre (3 ft), Class 2, most commonly found in mobile devices, 10 metres (33 ft), and Class 1, primarily for industrial use cases,100 metres (300 ft).[2] Bluetooth Marketing qualifies that Class 1 range is in most cases 20–30 metres (66–98 ft), and Class 2 range 5–10 metres (16–33 ft).
#2993
Not sure if this is listed anywhere?
I found code for Auto/Manual Regen
IPC original code no REGEN 720-07-02-0A42-48C4
MOD w/Auto REGEN 720-07-02-0A4A-48CC
also seems to of had trailer blind spot but not needed since XL
Original w/out 720-09-01-4020-0100-089A
w trailer blind spot 720-09-01-C020-0100-081A
The ford video's online state this feature is great for people who use there trucks for heavy city driveing. It can only be activated after a few criteria are met. My filter currently is only 70%.
#2998
Has anyone figured out, how to enable manual regen with active regen inhibit with forscan?
I suspect the needed lines will be located in the IPC and possibly BCM?
https://www.ford-trucks.com/forums/1...e1512436867832
#2999
I'm new to Forscan. I've only done a couple changes. With that said was wondering if anyone knew the coding to add just the chmsl camera. Not sure about 17 but 18 you could order it separately. Or if there is a way to read what module and lines would control it so I could compare it with one that is programmed from factory. Thanks
#3000
Installation
All vehicles
1. To install, reverse the removal procedure.
Vehicles equipped with a high mounted stoplamp mounted camera
2. Using a diagnostic scan tool, following the on screen instructions for the LIN New Module
Initialization-BCM configure the BCM.
Seems like if it can't be figured out in FORscan, a Dealer could initialize it.
