2017-2019 Super Duty FORScan Spreadsheet
#631
After this I'm really done. This is the part you're not getting...you don't need to download any program to open the license file, you don't even need to tell Windows how to open it. All you need to do is download it and know where your browser saved it. Then you need to know how to navigate to the folder where it's at in the forscan section where you press the button to load the file. By the looks of your screenshots it looks like you already associated anything with the .key extension filename to the registry somehow. So you've already gone way too far and are need of someone proficient with computers to help you resolve this. Don't try opening the license .key file with anything but FORScan.
#632
Yay!! We can move on from Windows101 and get back to Forscan!! Haha, glad you got it. Hey LivNitUp, I'm wondering if you or anyone else can send me all your stock BCM modules? I'm having trouble with my dimmer still and I'm wanting to make sure it's nothing I've done before I bring it in to dealership. I started saving changes but only started logging the changes after I started noticing the dimmer locked only when at night. During the day it isn't locked.
Also, wondering if there's a way we can set the daytime running bright lit c-clamp led to run Bright (Full 12v voltage) with headlights? I'd LOVE to keep them bright with headlights!!
#633
Is anyone annoyed with having to press the left or right had mirror buttons before you can make adjustments to the Power Exterior Mirrors? Don't want to sound lazy but I wish the last mirror I selected stayed selected rather than completely turning off into a neutral position after 30 or so seconds. Does anyone have a FORScan code to remember the last selected mirror?
#634
** if it's your first time visiting the above link you need to put in your country so a cookie is set, then click the link above a 2nd time.
If I were in your shoes I'd put BCM back to original and backup, then repeat the mods you've done to that module after truck is back from dealership. I'll look and see about the DRL on full voltage and report back.
#635
Rather than comparing your own BCM to someone else's, you should just put your VIN in here and pull up your own as-built BCM values and compare them line by line since you don't have a backup: https://www.motorcraftservice.com/AsBuilt
Thank ya sir! Hey while I have ya.....I done the mirror mod and didn't like the non Lincoln option so I went to the Lincoln option and that one def does the trick for me!! Thank you, I'm curious.......if I went back to stock module codes, and swapped the pins, would I be good without putting the pin 18-19 back stock?
#636
#644
This thread as mentioned before is mostly about Forscan, not windows operating systems. Others are going to start hating on you. I suggest you check your operating systems help system. There should be detailed instructions to connect to a bluetooth device. Short of that a google search of how to connect a bluetooth device to my laptop would sort it out just as quick.
I sincerely do wish you well.
