Is the dashboard on the new Super Duty exactly the same as the 2015+ F150? I want to get an XL dash surround off eBay and they only one i can find is for a 2015 F150. You think its a direct swap?
I know the cabins are supposed to be the same but I wasn't sure what all the entails.
Highly doubt it. It MIGHT be shaped the same, but Ford made sure they did some different things with the layout of the SD. There are several differences.
The dashboards are *exactly* the same except for the "upper" glovebox in the Super Duty which is just a shelf in the 150. The tachometer is different on the diesel trucks, there is a turbo boost gauge which may or may not be there on an EcoBoost F-150, and finally the buttons at the top of the center stack can vary a gazillion different ways on both the 150 and Super Duty, depending on whether you have cameras, hill descent, auto stop start, diesel exhaust brake, etc.
