Clutch switch
Old Aug 24, 2003 | 12:16 AM
ford2go's Avatar
ford2go
Question Clutch switch
88 F150 6 -- I have to push the clutch nearly thru the floorboard
to start. DO I have to pull the instrument panel to hget to the
clutch switch -- seems to be pretty high on the firewall.
Also, can I just wire it out -- I don't use the speed
control, but it also hooks to the computer, and I don't know why
Thanks
Old Aug 24, 2003 | 12:22 AM
steve83's Avatar
steve83
Clutch switch
It's easy to adjust, and easy to reach. It's above the gas pedal wrapped around the clutch master cylinder pushrod. The Haynes manual shows how to do it.
Old Aug 25, 2003 | 12:08 PM
c_rossman's Avatar
c_rossman
Clutch switch
You might need a bushing kit, you can buy the kit at ford for like 10 bucks, If you have any play in your pedels, thats your problem.
