check engine light 89 460 code 35
Old Dec 30, 2001 | 01:27 PM
isac50's Avatar
isac50
Old Dec 30, 2001 | 05:41 PM
daspud's Avatar
daspud
Post check engine light 89 460 code 35
89 f250 460 check engine light
on intermittantly under acceleration light and heavy. code 35 set , evp sensor voltage too high ?? , replaced sensor , still have code 35. also have hard startng after truck is warm and has sat for only a couple of minutes. long cranking if key is released then turned to start again engine will start normally is it possible these 2 problems are related ? thanks for any advice
Old Dec 30, 2001 | 11:20 PM
PAUL_2's Avatar
PAUL_2
First check to make sure the egr valve is closing fully , It may be carboned up to the point where its staying open , this would account for Code 35 & the hard starting problems . Also check the electrical connector to the Evp to make sure its making good contact with the Evp sensor . Are any other codes present ?
Old Dec 31, 2001 | 07:07 AM
daspud's Avatar
daspud
thank you i will check the valve and connection. no other codes present except 35
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
