Stumble
Old Nov 4, 2016 | 02:42 PM
barnyard's Avatar
barnyard
Also, you might check the carb to intake manifold hardware, make sure its tight. If the carb has not been off for a long time both gaskets probably need replaced. I like to put a light layer of white lithium grease on each side of both gaskets to help ensure a good seal.
Stumbles and hesitations sometimes hurt the powervalve also.
Old Nov 4, 2016 | 03:58 PM
D-rat's Avatar
D-rat
I actually bought new gaskets, but I sprayed a lot of carb cleaner all the way around the base of the carb with the truck running and not so much as a hiccup. I really don't think I'm pulling any air in there.
Old Nov 4, 2016 | 10:49 PM
barnyard's Avatar
barnyard
yeah used a lot of carb cleaner trying to get it figured out also. Mine was the gaskets and powervalve and throttle shaft wear. I even stroked a file across the pull off spacer and carb base plate, none of it was perfect.
I often try to remember how these things ran off the show room floor. So spoiled by FI.
Old Nov 6, 2016 | 10:40 AM
D-rat's Avatar
D-rat
Yes, trying to rule everything out before just getting a reman'd carb.
Old Nov 6, 2016 | 11:41 AM
D-rat's Avatar
D-rat
Originally Posted by Filthy Beast
Good deal...we'll all be waiting to see what you've found.
Any manifold vacuum will do for setting the carb's mixture.
For checking the distributor's vacuum advance can's diaphragm and breaker plate.... you can pull the line off the can's nipple and attach the vacuum gauge's line to it, or, pull the vacuum line off the ported nipple on the carb and use it. The engine doesn't have to be running to do this.
ok. i pulled the vacuum line off the distributor and hooked up a clean hose to it. popped the cap and sucked through the hose. there is no movement on the arm inside the distributor. i then tried blowing on the line. i can hear the diaphram in the canister when I do this. so is it time for a new distributor, or can you service this.?
seems that arm in there should move freely when vacuum is applied. hope this is the cause of my issues. im also getting a backfire put the carb if I really stop it down in 3rd gear... truck stumbles, backfires, and then it goes. this thing seems like it wants to make good power but it just wont.
checked timing. 800 rpm appears to be 15 degrees or better...hard to get a good reading in bright sunlight.. timing does advance as ms increase so mechanical advance is working. no ping whatsoever.
lastly, where are the mixture screws on this carb? nothing on the front near the accel pump.
Old Nov 6, 2016 | 05:08 PM
Filthy Beast's Avatar
Filthy Beast
You can get a new vacuum advance can just about anywhere. DSII distributor, correct? and a..2150 carb, yes? And if you can't apply a vacuum source to the can other than your own sucker, you'll have to do it with a strong vacuum.... I hope you did.
Yes, it should show a noticeable retraction under vacuum.
Good....on the mechanical advance and no pinging. 800 RPMs is still too high for a stick....so is 15 BTDC for a stock engine. Can you get it down to 650 RPM and ~ 12 degrees BTDC?
Mixture screws are in the front and under the accelerator pump.
Old Nov 6, 2016 | 06:19 PM
D-rat's Avatar
D-rat
was only able to suck it by mouth (that didnt read well....lol). Cant imagine engine vacuum would be much stronger. Will look for an advance can. Seems I could replace it without pulling the distributor....maybe. AC compressor bracket might be in the way.
I ran out of adjustment trying to get the idle below about 750. 15-16 degrees of tining there if my pointer is accurate, but no ping. I need to vheck early in the day tho when I can see the timing marks a little better.
Will look for the adjustment screws to try to maximize vacuum. What do you think is causing the carb backfire? Too lean?
Old Nov 6, 2016 | 06:52 PM
Filthy Beast
It's easier to replace the can without pulling the distributor, in my book. Glad you "procured" a substantial vacuum....hehe.
Ok, good on the checking the timing.
Ran out of adjustment to get the idle down? Definitely play with the mixture, timing and check for vacuum leaks.
Back firing through the carb can be an indication of a too lean a mixture, vacuum leak, timing, a faulty accelerator pump, crossfiring - plug wires # 5 and 6 being old and leaky would do it - or a cracked distributor cap or all of the above.
Old Nov 7, 2016 | 09:24 AM
D-rat's Avatar
D-rat
LOL...that really narrowed it down.
You know all these symptoms have acted like a vacuum leak from day one, but I've replaced everything questionable and I simply can't find any other leaks with the carb cleaner method. The more I do, the more I'm leaning towards just slapping a new carb on this thing and being done with it, assuming I rule out everything else. My dad suggested fuel pressure could be an issue on the mechanical pump as well. Not sure how to check that though when the engine is falling on its face under acceleration.
Will get out and set mixture when I have the time to do so. Hitting Napa after work today to see if they have a new advance gizmo.
Old Nov 7, 2016 | 07:55 PM
Filthy Beast
Alright! I'm happy I nailed the backfiring through the carb problem for ya!
Fuel pump/pressure considerations might come into play if you had no "squirts" in the venturi while blipping the throttle on a cold engine....or hard starting.....or the smell of gas in the oil.
I don't remember if you said you rebuilt the carb....?
Let us know how the new advance can works....it probably will come with some springs...and mebbe a small allen wrench which is used for adjusting when vacuum comes in. We can get to that later.
Old Nov 8, 2016 | 10:42 AM
D-rat's Avatar
D-rat
Have not rebuilt the carb. going through all the easier stuff first. If it does come down to needing a rebuild, I may just go the reman'd route instead. I know it's more dough, but I'd probably feel better about it.
So Napa had two parts listings for the vacuum advance but they couldn't get either one. They ranged in price from $26-42, but an entire new distributor was only $59 so I just did that and will feel good having all new electronics inside. Will get that swapped hopefully Friday, and will reset timing and tune engine vacuum then and see where it goes from there.
Any other tips on finding vacuum leaks? I've gone through a full can of carb cleaner hitting the ends of all vacuum lines, around the carb base, side of the carb where the throttle goes through, etc.
Should I assume that the new distributor is adjusted properly or do you guys think I'll be needing to messing with spring tension, etc?
I don't have much drawing vacuum....EGR, Brake Booster, Distributor, and PCV. Most of the ports on the manifold tree are capped, and don't appear to leak.
Old Nov 8, 2016 | 01:59 PM
barnyard's Avatar
barnyard
Carb rebuild kits are cheap, I would try the rebuild before spending the money on a reman. Just ensure that the carb is thoroughly cleaned and ALL passage ways are clear.
Just for the heck of it, spray some WD or carb cleaner along the intake to head gaskets while its running to rule out a bad gasket.
Old Nov 8, 2016 | 02:45 PM
  #28
D-rat's Avatar
D-rat
will see. Let me eliminate all other possibilities first. I know my vacuum advance is hosed...so that gets fixed first, followed by more tuning and timing adjustments.
Good idea on checking the manifold itself for leaks. I'll try that.
Old Nov 8, 2016 | 07:29 PM
  #29
Filthy Beast
Good idea about eliminating other stuff. Troubleshooting techniques are best done one at a time so one knows what the situation/illness is before being fixed.
Old Nov 9, 2016 | 12:56 PM
  #30
D-rat's Avatar
D-rat
Word.
