Diff fluid change
Old Aug 23, 2003 | 02:43 PM
MrDeath8666's Avatar
MrDeath8666
Diff fluid change
I was just wondering if i should change the diff oil on my truck yet, its a 91 f150 4x4 with 105,000 miles, no limited slip. I have no idea if the owner before me ever changed it or not. I just thought maybe its time since its a 13 year old truck now. What oil would you guys recomend? And ive been hearing bout that RTV stuff, where can i get that at? Thanks for the help.
Old Aug 23, 2003 | 07:42 PM
andym's Avatar
andym
Diff fluid change
Just use 75W90 synthetic gear oil. Do both front & rear at the same time. You will need a suction pump to do the front as there is no drain plug, just a fill plug. You'll probably want a new gasket for the rear, too. The diffs are full when fluid runs out the fill plug.
