Fuel problem
Old Oct 23, 2016 | 09:07 PM
TylerF100's Avatar
TylerF100
Fuel problem
1995 F150 4.9 Gas dual tank. Hello I am 16 and I am having a problem, my truck won't start. The truck only starts on starting fluid. The front fuel pump hasn't worked for a long time and I have just used rear tank. The engine won't start now and isn't getting gas. I replaced the rear pump today and fuel filter. Hoping to fix the problem. I tested the old pump and it was still good. So now I have an extra pump. I can hear the relay but can't hear the fuel pump. I checked all fuses and relays. It must be a wiring issues right? Any common places to check? Any help it really appreciated.
Old Oct 24, 2016 | 09:18 AM
rla2005's Avatar
rla2005
Check the inertia switch behind the passenger side kick panel (circled in red).
For reference:
Old Oct 24, 2016 | 09:23 AM
rla2005's Avatar
rla2005
A fuel system diagram of your 1995 F150:
courtesy of Subford
Highly suggest you use a test light to troubleshoot the circuit if the interia switch checks out okay. Be aware power is only applied for 1-2 seconds when cycling the key switch from Off to Run. To keep the fuel pump relay energized jumper pins 2 & 6 on the diagnostic port located near the driver side hood hinge.
Another helpful photo:
courtesy of Subford
Old Oct 24, 2016 | 11:17 AM
TylerF100's Avatar
TylerF100
For reference:
Thanks so much that was the problem!!
Old Oct 24, 2016 | 11:20 AM
rla2005's Avatar
rla2005
Glad you found the root cause. Thanks for the feedback!
Old Oct 24, 2016 | 06:49 PM
Glenn54's Avatar
Glenn54
Glad you got it fixed. I sure learned something.
Cperkins
Apr 29, 2018 03:14 PM
Joe097
Jan 30, 2016 08:59 AM
ShadyDog
Jul 12, 2015 11:36 AM
AWick20
Apr 7, 2010 03:31 PM
dblack45887
Sep 21, 2009 07:46 AM
