Aftermarket Products
Sponsored by: Worksport
Horsepower
Old Aug 23, 2003 | 01:11 PM
nd4spd's Avatar
nd4spd
Talking Horsepower
ive got a 90 f-150 w a 302 running true duals k and n filter and 383 gears....looking for something off the wall maybe cheap to make it pound the pavement better...any ideas??
Old Aug 26, 2003 | 11:26 AM
95 F150's Avatar
95 F150
Horsepower
Advance the timing a few degrees and throw on some underdrive pullies.
Keep on truckin' ...Mike
Old Aug 26, 2003 | 02:20 PM
nd4spd's Avatar
nd4spd
Horsepower
thx for the info mike.....i was thinking of getting some pulleys, thats about 15 hp and getting/making cold air intake systems, another 15+....i think ill notice a major diff.....
Old Aug 26, 2003 | 09:19 PM
95 F150's Avatar
95 F150
Horsepower
No problem , yeah pullies make a noticable difference in power and they're cheap too . I just bought a K&N and cut the bottom off the air box to make my own air intake system.
There really is no limit to what you can do with these engines they respond pretty well to modifications.
Old Aug 26, 2003 | 09:22 PM
gotstuk's Avatar
gotstuk
Horsepower
if you off road don't try this but for a steet truck its pretty sweet. do the old ram air that hot rodders did. make an airbox and run some dryer vents to the grill making a hidin ram air set-up. it might be worth 19-15 hp fo about 5 hours work and under 50 bucks
Old Aug 29, 2003 | 06:40 PM
RawPower's Avatar
RawPower
Horsepower
How much for the intercooler ("cold air intake system") and what are the pulleys yall are talkin about.
Old Aug 30, 2003 | 10:11 PM
ArkansasFordMan's Avatar
ArkansasFordMan
Horsepower
The pulleys that they are refering to are underdrive pulleys. Basically they are oversized pulleys that go on all your engine accesories such as A/C, water pump, and alternator this causes these items to spin slower causing less parasitic drag on the motor thus giving it more power.
Old Aug 31, 2003 | 03:32 PM
95 F150's Avatar
95 F150
Horsepower
My underdrive pullies are considerably smaller than the factory ones. I bought an overdrive alt. pulley to help with charging at idle it was 1 3/4" vs 2 1/2" stock. Like mentioned in the previous post the pullies slow down the water pump, smog pump, power steering and the air conditioner reducing drag on the engine to increase horsepower.
For the money they are a good engine mod, easy to install and a decent power return .
Old Sep 1, 2003 | 11:01 PM
muscletruck7379's Avatar
muscletruck7379
Horsepower
k&n, true duals, good place to start, after the cold air and pulleys i would put on a hotter coil and open up those spark plugs! another big point is making sure the truck is up too snuff, new plugs, wires, rotor, cap, oil and filter, and make sure your running synthetic lube, i prefer the quaker state stuff in the clear bottles, while your at it put the synthetic stuff in your tranny and rearend, well, the trucks rearend.
Old Sep 1, 2003 | 11:33 PM
dtpatt2's Avatar
dtpatt2
Horsepower
DO changing the pullys affect the water pump and alt's performace? Does the water pump pump less water? Or is it like you rear end gear, they just have to work less? thanks.
Old Sep 2, 2003 | 07:55 PM
muscletruck7379
Horsepower
actually they wont turn as much juice, but it should be fine if your charging system is up to snuff, and if your truck doesn't have cooling problems, you should be just fine
Old Sep 3, 2003 | 03:32 PM
skyhighlifts's Avatar
skyhighlifts
Horsepower
Try a throttle body spacer.
Old Sep 4, 2003 | 01:05 PM
95 F150's Avatar
95 F150
Horsepower
I've read and heard that throttle body spacers are just expensive paper weights . Get the pullies you won't be dissapointed, very easy to install.
Old Sep 4, 2003 | 05:39 PM
muscletruck7379
Horsepower
i think that throttle body spacers add only to the top end.
Old Sep 6, 2003 | 06:23 PM
true4.2's Avatar
true4.2
Horsepower
Any of you familiar with underdrive pulleys for the 4.2L V6?
