Basic Mods
Old Oct 22, 2016 | 09:12 PM
SkoalDipper's Avatar
SkoalDipper
Basic Mods
Howdy guys I'm pretty new at this modding stuff and I'm looking for some basic modifications I can do to my old 91 f150 302. I've already got plans to replace my intake, and a bigger throttle body, maybe some performance headers. Like I said though I'm pretty green at this so any help will be appreciated. Some basic things, I will not be doing an engine swap or any internal mods. Strictly bolt ons right now
Old Oct 22, 2016 | 09:51 PM
jplinville's Avatar
jplinville
Place an egg under the accelerator pedal for better mileage...
htownoag's Avatar
htownoag
Bump up your timing
Crane Mustang 1.7 Ratio Roller Rocker Arms part #44746-16
Street fire cdi ignition box part number 5520
Street fire tfibcoil coil 5527
Old Oct 22, 2016 | 09:53 PM
htownoag's Avatar
htownoag
Talking
I don't think that qualifies as a modification
jplinville's Avatar
jplinville
On a serious note, welcome to the site. You'll find many more helpful folks than me, I'm sure.
I take it that the truck is mechanically sound enough to be ready for upgrades?
Old Oct 22, 2016 | 10:07 PM
SkoalDipper
yes the truck is running well now. After a new plugs, wires, intake and valve cover gaskets, distributor cap and rotor kit, duralast ignition coil, when I took off the valve covers everything was in great condition
Old Oct 22, 2016 | 10:11 PM
SkoalDipper
I'm confident
Old Oct 23, 2016 | 12:14 AM
arse_sidewards's Avatar
arse_sidewards
Originally Posted by SkoalDipper
I'm confident
Make sure you know the pros and cons of everything before you do it if you want to keep your truck running well
Old Oct 23, 2016 | 09:19 AM
Conanski's Avatar
Conanski
If you're just looking for something to do then fine but those two mods will net you a grand total of zero gains, with this vintage motor there is nothing even close to restrictive upstream of the camshaft. The exhaust on the other hand needs some work so knock yourself out just don't go too big or you will lose what little low rpm grunt this motor has, don't put anything bigger than 2.5" pipe on for a single exhaust or 2.25" if duals.
Old Oct 23, 2016 | 04:25 PM
SkoalDipper
alright. Well one of the earlier replies said rocker arms so i might do the 1.7's on the exhaust valves only because that setup gave the best performance increase. And as far as the intake upgrades the truck is almost all original so it could use an update lol. Got this truck when I was 17 I'm now 19 and I've done all the work myself and I'm pretty sure I'm the best owner this thing has had. Like seriously when I got this truck it was misfiring, losing a quart a week, go 60miles on 3/4 of a tank, brakes barely worked, a/c didn't work, windows didn't work, bearings were shot all around, ignition coil, plugs and wires. I can do the work I'm looking for ideas cause like I said this is my first attempt at after market mods
Old Oct 23, 2016 | 10:17 PM
HIO Silver's Avatar
HIO Silver
Always improve the exhaust side before modding the intake side of the engine.
Old Oct 24, 2016 | 05:51 AM
axehandle58's Avatar
axehandle58
Slightly different kettle of fish for you to sniff over, but I just removed headers & 2-1/2" duals on my '78 351M. Headers leaked & rotting out, went back to manifolds, Y pipe + original muffler. No tail pipe; just loud enough so I can hear it. Maybe imagination but seems to run smoother now, especially just off idle. Definitely much better to drive.
Old Oct 24, 2016 | 05:42 PM
SkoalDipper
also i have some questions about my rear gears. right now i think its the 3.55 how does that affect performance?
Old Oct 24, 2016 | 06:20 PM
Conanski's Avatar
Conanski
That is a pretty good driving around gear for a truck with relatively stock sized tires, but if you want a bias more towards performance and/or if the tires are larger than 31" go to 4.10 or better.
bubbareitz
Jul 8, 2015 09:17 AM
SkinnBO
Aug 3, 2012 09:45 AM
deereboy89
23
Sep 4, 2007 05:05 PM
SASKY
Feb 21, 2006 02:07 PM
ekstewe
Jun 18, 2003 07:20 PM
